you keep saying about getting arc eye and therefore letting your mate weld.....do you not have a mask??
yes as the posts reads.
Mask is poop hence why i didnt use it. Nevermind job done. Old news
So I had a day off today to get some work done. After a few hours and alot of stressing about the engine and or car falling we had it mounted.
http://i25.photobucket.com/albums/c5...h/DSC00252.jpg
Yeh baby!
I forgot to bend the clutch cable exit :( So it looks like we are re-routing the clutch cable. I also forgot to pull the PAS pulley off the crank so it looks like Ill have to do that next weekend. Apart from that, the clearence for the alternator belt looks ok.
I have an issue with the passenger side mount. I cant remember exactly how to rebuild the mount. I have it bolted to the XE side, put the rubber bush in and bolted that in. Its the bolt that runs through it all. I dont have enough clearance to stick a nut on the back as the gearbox is in the way.
http://i25.photobucket.com/albums/c5...h/DSC00253.jpg
take it !!!!!!!!!
need help please peeps, gearbox wedged against body, any ideas why ?
I had to put washers between the mount/gearbox to space the box away from the mount when i did mine. Cut dow the end of the bolt so i could get the nut onto it. Was still a very tight fit though
Excellent stuff mate, once again Richie to the rescue!
We (me and Jimbob) had a quick tinker after work. Jimbob slackened off the back mount and we found there is a little bit of adjustment, this helped. We also discussed spacing it, so this looks like the way forward.
We also started on the exhaust, jesus the manifold is l o n g. So we decided the best approach would be to to cut the centre section, mate the cut bit of centre section to the manifold and refit the manifold to the engine. Then chop some more off the centre section and weld it.
Pikey tool co.
Saliva = free WD40
2x paintpots = workbench
ford ka = vice
on the gearbox you are also going to need to cut the lug of the gearbox or you wont get the tie rod arm on
Cheers kitt, do you reacon you could mark it on that pic using paint?
http://www.corsa-novatuning.nl/uk/PartsA.htm
There is a couple pics here about 3/4s of the way down. Will an angle grinder suffice?
