hoping that i can get a bearing of the right size to press into the shifter box and then going to make some sort of steel flange at work which i can press the bearing into and then weld to the bulkhead.Quote:
Originally Posted by garethcolley
I was thinking 15-20mm thickness for the spacer, but that will be a last resort if im not happy with the angle and function when everything else is in place
Rich
