haha my old flanges back?!? na mate ive got shafts already lol :thumb:Quote:
Got her bcak home now thanks to Jordyznova towing me home from work in his 1.0!! still having teething problems! the carbs are pissing fuel out the back on 1+4 im being told that because ive had them off the car the floats could be stuck? im also going to extend my starter/alt wiring. Gave her a quick boot down the road and . . yeah she goes well :P.
Going to have bash with the wiring in a min and my mates going to pull the carbs apart. Then its remove rear seats and hoover inside and give her a clean!!
hows it going m8 any further forword with the carbs
well the leak stopped but it started again now gave it a quick blast up the road earlier but came back and no1 carb was leaking again so going to pull the carbs aspart again tomoz :D
Nearly there then, that all that needs doing?
yeah mate shes booked in for mot at 3pm tommorow everythings done now but cant risk driving it with fuel dripping like a kant! :(Quote:
Originally Posted by Steve
Hope all goes well dude, any luck on them caps?
still rooting through all my **** in a dinner time mate ill have another nose tommorow :thumb:Quote:
Right todays update -
took carbs apart all seemed ok again but used uransol blue or something like that to seal the no1 carb up as the gaskets abit w@nk. So brought them home and put them on and it went to fire but hesitated and then the battery died grrrr so pushed it down my road and ended up getting it stuck! So me bro came with some jump leads and the 1 pop and i got her back home so as of then no fuel leaking. So now decided to see if i could drive round the block. Had to mole grip the throttle cable as it keeps going to cut out when on idle, so did that and drove round the block doesnt seem to bad nothing to jump around about as its farting and spitting im hoping that after the umpteen times of cranking the plugs are funked. Also need to reset gears as 1st and 2nd are hard to get. And im hoping its the battery thats funked need to see if the altenator is charging. Took some quick piccys in the dark -
http://i49.tinypic.com/afc38z.jpg
http://i49.tinypic.com/30kdohj.jpg
http://i45.tinypic.com/2vhuiy0.jpg
i cameto the rescue again =] 1pop way forward
