Thought you'd of tried to get a cleaner shell?
Weirdly, this one is completely rust free in all the right places!! The front turrets are solid, the rear chassis legs are solid, the rear inner arches are also solid, one outer arch is solid, the other is just starting to crust away.
This
http://i27.photobucket.com/albums/c1...B9966AE6B4.jpg
Is all the result of a poor battery tray repair, Ben seems happy enough with what he's got to work with, pronouncing it "solid in all the right places"
It'll be alright!! wire wheel and a some kurust and she'll be right!!!
Doesnt seem too bad that, makes me realise how good the shell i have is, and also how good the last shell i had was too before i moved it on though.
Fongers crossed my 'plan' comes about and project 'fibreglass shell' will end up in the making. Id only ever have to worry about rot on the first half of the floor pan, the bulkhead, and inner wings then.
Bought not built what a waste of money. You suck!
The shell I have now is rust free, however the roof skin replacement is beginning to annoy me, half cage is rubbish, I can't be bothered to cut the cage out and put a new one in. It's easier to start again and try and get it as right as possible from the start
I know, don't worry though I've got 1000's to throw at it!!
On to today, I didn't think it was hot enough, so I fired up the grinder and welder to play around with this.
http://i27.photobucket.com/albums/c1...552C1C5A51.jpg
It's a nice .5 litre catch can but it's got M16x1.5 inlets allowing me to use AN8 fittings as shown earlier for my breather system.
First up, something to mount it on
http://i27.photobucket.com/albums/c1...33C0F3A022.jpg
Then adjust the hose that used to go direct to atmosphere to meet up with inlet 1, Then hose 2, the outlet with a nice 90 degree on it down to atmosphere
http://i27.photobucket.com/albums/c1...F7620F1333.jpg
http://i27.photobucket.com/albums/c1...69D65BB06F.jpg
Find somewhere nice for the outlet to sit, will run to the rear of the car once the new shell is done, to keep it away from any tyres!!!
http://i27.photobucket.com/albums/c1...D953404C55.jpg
Happy enough with that, decent progression from what it used to be, all part of the fun!!
Ah ok over the rust and nice tidy job with the catch tank.
I love the oil lines unions etc. Look proper. That will have to go on the new engine.
tidy work mate, looking good.
Yep, all a mock up now for the new shell
Thanks mate, not as tidy as yours!!
4 wheel alignment and slick slick fitment ready for Bedford on 1st August!!
Passat needs a clutch too, started slipping whilst towing the trailer on the way home from Billing!! Ball bags!!
Nothing too exciting this week, been busy working at Next in Doncaster, lovely job!!!!!
Got this ordered as since fitting the new seat I wasn't happy with the steering wheel being so far away
http://i27.photobucket.com/albums/c1...4B5DD17230.jpg
It's a 35mm spacer, could probably have done with a 50 or even a 60 but it feels so much better than before.
Without having to take the dash out to weld braces in to the column mounts I added these little fellas that I had in the gash box.
http://i27.photobucket.com/albums/c1...02E01FDC68.jpg
New shell will have a completely custom column so this has become a test bed for wheel position, the Tilton floor mount pedal box will be on an adjustable plate to allow for some tinkering, but I'm really happy with how far away from the seat the pedals and wheel are at present so will try to replicate that with some adjustment.
Shamelessly stole this from Dar (with his permission), after ordering one batch too big I got the second lot spot on.
http://i27.photobucket.com/albums/c1...3E8674B1DB.jpg
Bit of a pain to bend but looks trick!!
http://i27.photobucket.com/albums/c1...8558BC1A38.jpg
Quick trip to the chippy to check it was working!!
Also got my new, second hand, Michy slicks fitted to the new set of Cesaros I picked up Friday, they along with the orange ones will be off for powder coat soon.
Whilst removing the 888's I noticed the rears were "rolling the tread" (can't think of a better way to describe it) on half the inside of both wheels, it seems that the inner half of the tyre is barely in contact with the track, after speaking to those that know, we need more rear camber. Cue some Eibach rear camber adjusters on order!!
Hoping for 4 wheel alignment Saturday morning, then Bedford Monday, first time out on slick slick.
Oh and on a side note, golden flecks in this evening's oil change!!! Poor old girl is starting to have had enough!!!!
