They will be bolt in - as you will see in a bit lol
Big thanks for the link - its exactly what i wanted :thumb:
No worrie's oh and the seat's use to belong to Chris T before Olly lol his car has parts all over the club!
Looking good so far :thumb:
A few words of wisdom on the seat rails :
You may find the spacing on the rails doesn't match the holes on the bottom of the seat mounts (You've probably checked this already - but not took pictures lol )
If your drilling straight through the box section - the correct method is to insert/weld a tube into the box section so it doesn't collapse/crush when tightening down the seat mount - personally I can't see your box section collapsing when bolting down the seats - but thats what the experts say !!!
The easy fix for this (The above 2 problems on my project resulted in the following -) is to weld brackets to the box section and drill to suit the spacing on your seat mounts :
http://img.photobucket.com/albums/v5.../seatrails.jpg
Dave
Or there is the way mine were done, use some L shaped section steel.
You can gain access to the nut/bolt from front/back side of each section and there's no chance they will fold as it's an L shape ;)
http://img520.imageshack.us/img520/1...0237smallv.jpg
Thanks people advice taken on board...but i can see the box collapsing either lol
Hi everyone not really an update as i haven't done much mainly due to this taking over my evening
http://www.pngclub.com/forum/showthread.php?t=116201 :D
I did however get the drivers seat mounted, I started by fitting the seat to the sub frames then resting it on the new rails and positioning it in a comfortable position.
I found the most comfortable position for the seat was the front slightly turned in towards the centre of the car and the seat close to the exhaust tunnel.
Once it was positioned i clamped the subframes down and removed the seat allowing me to mark out the holes as so
http://i248.photobucket.com/albums/g...ndseats068.jpg
Then i drilled the holes and fitted it all back into place - it fits yay!
http://i248.photobucket.com/albums/g...ndseats069.jpg
http://i248.photobucket.com/albums/g...ndseats071.jpg
PS the box didn't collapse lol
Looking good dude, love the lit up pics a few pages back too.
Good work.
Ta Benn i can't wait to get it painted now :DQuote:
When do you say the colour? When its painted?
I thought this might have given it away lol lolQuote:
