I thought the baffle went in first then the gasket. I'm pretty sure it was either Vaux or one of the motorfactors that explained that to me. I purchased a stainless steels screw sump kit off ebay.
http://img19.imageshack.us/img19/6491/1002015w.jpg
Need to return the rotor arm as it is the wrong one :roll:
http://i193.photobucket.com/albums/z...8/DSCN2504.jpg
this is my one, the gasket is part of the baffle. make sure you bend the correct tab out of the way before fitting it though.
So you saying that I don't need to fit a gasket? just the baffle with its own gasket?
If your fitting the gasket in the pic above yes. The let/xe us a metal one in between 2 cork gaskets which always leak, the rubber is the gasket with the baffle built into it so no need for anything else. You will need slightly shorter bolts so they dont bottom out.
Ahhh ok gotcha, must've misunderstood the chap at Vauxhall. So all I need is to buy the sump baffle with the rubber gasket and the correct bolts.
Cheers Rich :thumb:
been watching this for some time now mate and just signed up so i can now say i love it its came far from when i first seen this thread start, keep at it mate
wilson.
Thanks for the comment Wilson :thumb: Trying to use up as much of my free time lately to push it forward.
UPDATE
Woke up and went to check to see if the breather pipe had hardened. Great thing about my garage is that he boiler is located in there so in the evening when its on to give hot water it does get nice an toasty in there and with the weather being mild the garage probably hits 25 degrees easily.
It had dried properly and has come out real nice (bling, bling).
https://images2.imgbox.com/bc/b7/KUpJK5LZ_o.jpg0
http://img685.imageshack.us/img685/7087/1002217h.jpg
The postman also brought me a gift so I can now help protect a few more areas of the Nova, although reading the warning label has persuaded me to go buy some latex gloves before I use this stuff as 'it can harm the unborn child' :eek: Best not get pregnant!
https://images2.imgbox.com/06/51/WCWrIRwv_o.jpg
http://img594.imageshack.us/img594/5508/1002218l.jpg
UPDATE
Went and exchanged my rotor arm for the proper one
https://images2.imgbox.com/05/1a/zCsdjMd9_o.jpg
http://img191.imageshack.us/img191/8774/1002220a.jpg
and also remembered that I'll need a new one of these.
https://images2.imgbox.com/47/d4/bUPOB3eN_o.jpg
http://img848.imageshack.us/img848/558/1002221.jpg
Hoping to get some more work done in the garage but right now I'm absolutley starving and waiting for dinner to be ready lol
