Ah ok, thought you would of just dont looklike it around the back of the n/s turret and ah cool, much like what i thought you'd do.
Good up the good work.
It shouldn't look like it around any of the turret as ive seam sealed all the seams.
Protec sell the eccentric mounts your looking for, I had them on my nova and so did Ad, I've never quite understood why the others people are using are made that way knowing that they require the strut tops modifying
by having the bearing on top you can then run lower surely...?
Just use shortened dampers like Rick does, my nova sat fine, handling was awesome and it didn't thave half the bits people use these days.
If people pick up the phone TBH and rang Gaz direct they would find they offer a couple of different lengths of nova/corsa damper....
Yes Rick you are correct....
Great work on the turrets & cage fitting Count. Its the kind of details & fabrication I like to see in these project threads.
aint been on for a few days.
some great work going on there with the turrets.
like how you make a potential problem made easy with the trusty welder and laods of patience.
Great project - worked my way back to page 35.....
Good to meet you the other night, hope the parts are a real help.
