Fair play starting again when the yellow one works so well
It's ok, I am thinking of going 4WD...Quote:
Originally Posted by Graeme
4wd it paul be rude not too
Wasnt me :tumble:Quote:
Originally Posted by Paul
Which shell would you 4WD?
The green/blue/silver oneQuote:
Originally Posted by AW06
Your a savage with a jack Mr Alex!
lol
It was too low, was easier to force the jack under it. Also the axle stands are a bit rough on it i know.
Good idea that Paul, i ****ing hate mine for slipping off the jacks at that point as it's all gone manky over time/repeated jacking etc..
4WD, humm who's going to create the best one then, you or Ste?
I keep thinking of welding over the chassis bits too, as mines been jacked up badly in the past. Beautiful welding there too.
Yeh, it is a good idea, it strengthens it up for future jacking, makes it look nicer, and also when you weld the plate , your acually adding quite a lot of strength cause its putting a proper box section over two seperate bits of chassis, that are otherwise only joined with 6 spot welds.Quote:
Thanks Ben, it is improving :)
Yeah all reasons i was thinking about, and yeah its got very good.
