good to see your still working on this bud and congratz on the sprog
i have appeared to have just bought a full mk2 golf zender kit...much like this one...
http://www.gti-engineering.com/images/RE2000a9.jpg
arches will fit near perfect as gti ones do, skirts ill have to chop a bit. bumpers...they will be fun. all for £75 delivered.
cheep that matey, when i had my mk2 all the lads with small.bumperd cars wanted them
it either that, or ill ling it on ebay for 7 days, see if it sells, if not ill keep it.
there is a guy on the mk2 golf owners club who is always looking for zender stuff
https://fbcdn-sphotos-c-a.akamaihd.n...90383398_n.jpg
cam cover got painted tonight...
Are you going to be mass producing them lol
Is that Triumph nuclear red?
:thumb: cover :)
from another 2 angles looking pinker/purple
https://fbcdn-sphotos-f-a.akamaihd.n...47208845_n.jpg
https://fbcdn-sphotos-a-a.akamaihd.n...50887951_n.jpg
lined the kit up...bit chopping and it'll fit
https://fbcdn-sphotos-c-a.akamaihd.n...65923520_n.jpg
https://fbcdn-sphotos-e-a.akamaihd.n...27138648_n.jpg
https://fbcdn-sphotos-f-a.akamaihd.n...03242369_n.jpg
this is going to be epic bub :)
cant wait to see it painted :)
well, pistons are in
https://fbcdn-sphotos-a-a.akamaihd.n...40172792_n.jpg
and 2 days of welding has lead me to ALMOST having the exterior welding done :p
https://fbcdn-sphotos-e-a.akamaihd.n...36374924_o.jpg
just both corners behind the light clusters to make up
https://fbcdn-sphotos-h-a.akamaihd.n...79919612_o.jpg
filler cap flushed as it was rotten and i couldnt be bothered to carefully make new bits up, ill mount the filler cap the other side inside the bed bit
https://fbcdn-sphotos-b-a.akamaihd.n...30707253_o.jpg
and just filling in the gaps with tiny offcuts. lots of fibreglass will be used
https://fbcdn-sphotos-a-a.akamaihd.n...84894756_o.jpg
https://fbcdn-sphotos-f-a.akamaihd.n...91069802_o.jpg
looking good bub :)
arsing about on soildworks to make the cage
https://fbcdn-sphotos-b-a.akamaihd.n...60051565_o.jpg
Lol at the kit, did you really want to fit it or just couldn't help but bid on it?
Oh look, 17 months later. No real updates other than I was told 6 months ago we were probably going to be moving warehouse so I sold my xe I spent months to save and and build. Found out after I sold the lot we weren't moving after all. Since I came into some money I went and bought my ex's cally t which I'll be ripping the let out of and throwing in the shell. That's also coming home to my place since I've got parking place for it and the calibra to break. Plus since my daughters now 1 is time she helped haha. I'll get some pictures sorted too
I always said I didn't want a let but I can put phase 3.5 chips back in it and have it back up to high 300s. I'm not sure, I think I'm going to stick with the original fantasy pink just because lol. I'm thinking about using expanding foam inside and sculpt the back of the cab then gel coat it. I can't think of any other way that is light. Once it's home I can do a bit in the evenings between spraying and polishing the list of wheels I've got to do. I can't stay on after work because I finish at 5 and girly goes to bed at 7ish and is the only time I get to see her during the week.
whats this POS i have sat on my drive?
https://fbcdn-sphotos-f-a.akamaihd.n...a361233643e837
https://scontent-a-lhr.xx.fbcdn.net/...5c&oe=54CA32A0
it still starts first time after standing for 3 years. currently building my shed to strip the let out, few other bits i want, sell the rest (god knows what) and then scrap it.
finally found the engine spec from that purple shed
Engine
FSE Power boost valve
4 Uprated Bosch Spark plugs
K&N 57i Kit
Straight through Scorpion Exhaust with Cat Replacement Pipe
Bailey Dump Valve
Front Mounted 9litre intercooler
Some silicon hosing
Dual Outlet Purge Kit
Turbo timer
Adjustable boost controller
Running EDS Phase 4 software and engine build (Now running phs1)
Comprising of Hybrid KKK Turbo
High Performance Actuator
Head is ported and polished
Bottom end re-bored to 2050cc
Top of block skimmed
Oil spray nozzles for piston cooling
Modified Big end bearing shells
Modified main bearing shells
Arrow Steel con-rods
Forged Low compression pistons 87mm sizes
Steel head gasket
Uprated Oil pump
Uprated Water Pump
Power Outputs
Standard 204 bhp
EDS Phase 4 370 bhp
figures approximate, probably lower than stated
Christ I remember that from years ago!
That front end looks really unhappy :(
How would you feel being made to look like that haha.
Where do you remember it from SRimon? It's been around down here for a good 10+ years
