Yeah but you drive like a man through the corners and I drive like a total pussy!!!
And if you are having an expensive manifold made (Edwards / Simpson) nows the time to decide.
Ben's work is spot on, you won't go wrong.
What the... really?
Ehhhh!Quote:
Should be collecting week commencing 11/7/16 then straight up to Hangar 30 for Ben to work some magic, need to get my bits ordered from Hockly, they were out of stock on the gear shifter when I called but they said they'd do me a deal if I bought that a cage and a plating kit at the same time so..........
Too bl***y right it is, I feel like I might have slipped into some sort of parallel Nova owning universe lolQuote:
It's all getting a bit Harry Potter and the Prisoner of Kazakhstan .
Bring it on...
sorry i thought the new shell was track spec'ed already. so took it, that it would be caged already.
Yeah, What's the dry sump kit from QED £12-300. I haven't had any oil pressure problems thus far. Also, others seem to have had a ballache fitting it, let's wait and see, if I get bored then I might do this.
Hockly said they were out of stock of shifter rods when I called to order, I spoke with Jess and explained I would be looking to but a roll cage, plating kit and shifter all together and she said they would look at a little discount for me. Only fair really considering it's nearly £1500!!
Edwards as in Edwards Motorsport?! I have been looking for a manifold and have seen that name around, seems silly to have that engine with a boggo manifold!!
Don't be sorry mate!! New shell will be a blank canvas and we're starting from scratch and doing it properly!!
So with Cadwell approaching a few little housekeeping jobs, well not really house keeping.
I've been having a really annoying intermittent mis-fire, sometimes it's fine, then bogs down, then fine again, I couldn't put my finger on it, changed the plugs, changed the 4 pin coil pack plug and soldered the wired to the pins, thought after yesterday it was leads breaking down when hot, so ordered new leads for Iain to collect for me for Cadwell, then tonight I fired it up and straight from cold, mis-fire!!!
Whilst it was idling, I got a pair of insulated pliers and pulled each plug lead off in turn, expected number 1 to be the problem as it's the oval oily bore!! but the only lead that made no difference was number 2, played around with the lead, closing the jaws of the lead up a little to make sure they were biting the pin and plug correctly, no difference!!!!!
Then tried the injector plugs, again number 2 no difference when unplugged, then as I went to plug it back in, some sort of green liquid inside the injector!! wasn't fuel, oil or coolant, didn't really taste like water but could of been, anyway, airline, blowjob, checked the other 3, 1 other had a little moisture, blown out. test driven, BOOOYA job jobbed!! Gonna fit the new leads anyway as current ones are past their best.
Now enough with all these words, lets get some pics going.
Since moving my seat, I've never been happy with my gear lever position, I know I'm going with the DTT shifter but wanted to try and improve things a little for Cadwell.
Knocked this up out of a bit of tube, double bent and welded.
http://i27.photobucket.com/albums/c1...D4F398C30E.jpg
http://i27.photobucket.com/albums/c1...F7997A8C6B.jpg
Came out ok, I think, garage is messy as buggery!!!!
Drilled the inside of the tube out to 12.5 so it sleeved over the existing lever, then tack tack
http://i27.photobucket.com/albums/c1...584181BAAB.jpg
http://i27.photobucket.com/albums/c1...5ECD057368.jpg
Moved the knob closer to the wheel and about 100mm higher, road tested, then welded in properly, cleaned up and sprayed. Feels a load better so much closer to the wheel, less time off the wheel and no stretching for first and third. That'll do donkey, that'll do!!
Oh and engine is ready!!!!!
Just need to collect!!!
Double BOOOOOOOYA
Nope, needs to go in the car first, I'd love to have it dyno'd and setup prior to it going in but I'm not able to spare the ancillaries from the car, throttle bodies and such to allow it to be done on the engine dyno, so in the car it'll have to be.
Possibly tempted by a quaife box aswell as I'm told the straight cut box will reduce box losses too. We'll see, if work carries on like it is now for the next 3 months then it'll be triple Booya!!!
OMFG
https://shop.quaife.co.uk/quaife-vau...ential-gearbox
I need this in my life
