yep.Quote:
Originally Posted by Nova_Tek
yep.Quote:
i run rs turbo ones also :)
So just rs turbo ones? Nothing special? Cause i can order them via work...
This is what My mates running in his LET Corsa, NGK - BCR8ES (also RS turbos) ;)
Can't believe they are that cheap. Sounds like RS turbo plugs FTW
just bought 4
Genuine Ford/Motorcraft ones.Quote:
I got mine from Matt Lewis Racing on ebay. :thumb:
i used to chat to matt when he came in halfords few years ago if its the same guy im sure it is. completly forgot about him. nice guy used to have a right laugh with him.Quote:
I got NKG ones from my work to try....Quote:
Front bumper has been primed, just needs flatting off and its ready to re paint.
whats wrong with it? did i miss that bit?Quote:
When cold it misses and bogs down and runs a bit poo.
sorry, meant front bumper
Oh haha just stone chips. Was getting peppered.
Stone chips there like a good case of piles !!!!!!!!!!!!! i fooking hate em
lol to much full boost driving.
What have i started?!
A boosted revolution?Quote:
Good question, but what the hell are you talking about?
Ever feel like you've gone over board?^
http://img.photobucket.com/albums/v3...n/IMG_9119.jpg
Stripped the wings off to give the car a good clean, as the paint under them hasn't really been touched since late last summer, so want to check everything and give it a good coat of wax.
Bit dirty.
http://img.photobucket.com/albums/v3...n/IMG_9121.jpg
Really just tidying things up as i clean, few jobs here and there.. Did like seeing the water return pipe.
http://img.photobucket.com/albums/v3...n/IMG_9117.jpg
So re ran it under the slam, above the headlight.. Nicer in my eyes.
Headlight wiring is bit untidy too, so i've started heat shrinking it up, wil help keeping it out the way too.
While the wings are off all the chrome bolts are being re painted.
http://img.photobucket.com/albums/v3...n/IMG_9129.jpg
As well are the bonnet lifters, which have patches of rust comming thru..
http://img.photobucket.com/albums/v3...n/IMG_9127.jpg
Sanded off,
http://img.photobucket.com/albums/v3...n/IMG_9126.jpg
Painted in bumper grey.
http://img.photobucket.com/albums/v3...n/IMG_9128.jpg
Bought my bumper home from the bodyshop to get all flatted off ready to paint on Monday.
http://img.photobucket.com/albums/v3...n/IMG_9130.jpg
http://img.photobucket.com/albums/v3...n/IMG_9131.jpg
Sure by the time i'm at Billing i'll have a stone chip...
Been building a nice collecting of parts...
http://img.photobucket.com/albums/v3...n/IMG_9122.jpg
New pads and one got cv grease in and is funked.. £50 down the drain there.. New disc needed too. New Rs turbo plugs and leads. Oh and a nice number plate with no crap on it.. Thinking of maybe giving it a light tint as nothing on the rear of the car is yellow so stands out.. Thoughts?
Black and silver show plates FTW! :thumb::dQuote:
painted wing bolts = WIN.
De-chromed bonnet lifters = WIN. (just 1 step left to ditch them all together)
The RS turbo plugs we told you about are gen FORD ones mate. Not NGK's.
Nice work Benn, my bonnet lifters have started getting some rust at the tops, need to sort them too.
is that a vectra st wheel i spot next to the bumper, i need one lol
Yes yes, wont ditch them tho, nice spec and hate bonnet stays, they look so messy. Plug i wanted to try out first, when i started it earlier it seemed better. But wanna start it early in the morning so its still proper cold to test it. If it fixes it then i'll look in to Ford Plugs. You'll be happy to know i gapped them too..lol And posted you a box of goodies on Friday.Quote:
Astra Dan did his for a more factory look, and that works and looks nicer too.Quote:
Yes its a bent one. Wanna use it to test to see how much a 7J rim will rub..Quote:
you will need a 10 mm spacer on the front, not sure on the back will let you know tomorrow.
i have a bent one too so need another :(
Why a spacer? Touching the leg?
Nice work dude..... when it comes to subtlety the wing bolts tone down the bay a hell of a lot when they arent chrome/zinc hence why I kept mine painted. Never got on with bonnet lifters as they seemed to alter the bonnet gap with nova hinges being so weak... Lastly Ill leave you with this........ ;)
http://i84.photobucket.com/albums/k2...g?t=1278240696
Nick.
if your not on coilovers on the front you havent got a hope in hells chance, the wheel hit on my gaz coilovers hense the reason for the spacer. pics in my thread :thumb:Quote:
Couple of layers of cling film on your bumper for the drive down to billing for an anti-stonechip protection layer FTW:thumb:Quote:
So cracked on, time to swap wheels to the shiney ones for VBOA at Billing. While doing it i did...
Cleaned and waxed and sealed inner arches,
Check my new brake lines,
Change my disc and pads too.
Finished re-routing the water return..
http://img.photobucket.com/albums/v3...llingprep8.jpg
Found i had a CV boot gone a month back, then at the mot noticed a bronze patch on my disc and the tester said it was pulling to that side a bit.. Tried cleaning the pad and disc. But CV grease had got in there good style and killed both. So fitted new M1144 Mintex pads and a new disc..
http://img.photobucket.com/albums/v3...llingprep4.jpg
Hhmmm must have a stiff chassis... lol :roll:
http://img.photobucket.com/albums/v3...llingprep6.jpg
Inside of the disk and dead pad...
http://img.photobucket.com/albums/v3...llingprep9.jpg
http://img.photobucket.com/albums/v3...lingprep10.jpg
Car back on the ground, had to pump this tyre up as the slim line alloy jack wouldn't come out from under the sill... lol
http://img.photobucket.com/albums/v3...lingprep12.jpg
Flatted the primer on my bumper off, flatted my boot grab off as it fot damaged when the boot opened in the garage..
http://img.photobucket.com/albums/v3...illingprep.jpg
I do like them, but i'd need to be back on 4stud, well i haven't seen a spacer/convo plate to do 5stud to 5stud 130pcd.
Ah yes i have Gaz coilovers on mine too.. Bugger.Quote:
Never stays on i found. Tired it once before and it came on before i got on the motorway.. Will have my bonnet bra on tho..Quote:
Originally Posted by Spudly
Update a page back.
Good progress mate, and nasty on the boot grab damage, thats them dam power lifters! lol
benn, there's a company local to me who custom make adapters for anything. Will pass you the number if you're interested. :)Quote:
Car is looking well, can't wait to see it again this weekend!
Cheers Scott, the boot opened very well even tho the garage door was closed..
My mate had ro close on the door..
John, yeah go on.. See you there..
Door cards are done :)
Am doing a bit more leather wrapping at the mo.. Its getting really hard!
Whats getting really hard Benn? ;)
Wrapping the boot strut. Wont stick. Is gonna be a c**t to sew up, but looks like the only way to do it.
The mirror bases have always annoyed me, they are plastic finish. But its a crap finish, wax doesn't bring them up nor does trim gel... So i've painted them in bumper grey...
http://img.photobucket.com/albums/v3...rrorbases2.jpg
Mucho better.
http://img.photobucket.com/albums/v3...irrorbases.jpg
http://img.photobucket.com/albums/v3...rrorbases3.jpg
good work buddy,
no spacers needed on the rear !!!
leccy mirrors?
thats what i though, but after a re think i realised they were the power lead for hi love eggs that he use when bored lol
