Not done any as my home computers dead lol
The last set look like the mini wheels Baxter has. Your would suit the Borbets IMO, my favourite wheel evvvvveeerr apart from ronal t's :d
Getting them in 5 stud (to save hassel) and in a good fitting size will be tricky...
David, so be a ps with Ronal t's too.. Had one ages ago..
Im trying to find a decent doner pic to show you what i would do if it was my car :)
If you can wait till tomorrow then the worlds your oyster for wheel ps's ;)Quote:
Please Lee, and i cant wait David.
Just imagine you're looking at this via a mirror lol
http://img.photobucket.com/albums/v2...oddy/benn5.jpg
I fapping love these rims, always have, always will!
http://img.photobucket.com/albums/v2...oddy/benn4.jpg
is that a golf?Quote:
Originally Posted by Lee
Love the turbo's, not liking the bbs rims tho.
er, how lol
your bay is cleaner than most cars paintwork on the outside !!!
only thing i could see that he could change is moving the lambda further down the system so you cant see it, other than that im stumped as to what else there is lolQuote:
Originally Posted by draper
I dunno. I caught a glimpse of about 5mm of unsightly injector loom lol
Originally Posted by Lee the ps apprentice
Agreed Lee, Benn get a set they would finish your motor off to a T ;)
Lee can I have my job back :cry: lol
Oh no, you've gone and done it now!!lolQuote:
Not in my eyes,Quote:
I have thought of that, but the down pipe welded in to the system, which runs to the back box. So its not easy to get off, i'm tempted too do it tho, as i don't think i could hide it. Wasn't happy that the king lead was blue, so painted it. Not good as its broken down the rubber, so when i started it sat morning and it ran like crap and i touched the leads while the engine was running it gave me a shock.. Quite a big shock. So a start king lead will hide better, need to heat shrink or cover the loom that go's to the hall affect sensor, as its a bit untidy.Quote:
Originally Posted by burgo
I wanna get the afm tucked right down under the slam panel if i can as it looks nicer, the air filter needs changing too. The water inlet to the turbo silicone pipe needs the metal fitting at the bottom bending in as it touches the rad if fitted the right way, hence why its at a funny angle, then it can be tucked under the slam nicely too..
See because of all the messing with the doors i didn't go alot i normally do.Quote:
The engine loom is normally covered with some "cut off" of the black silicone tubing that's in the bay. So it almost looks like a water pipe comming thru the bulk head, just tidies it up well nicely.
Now you see why i'd like different rims.Quote:
Originally Posted by Southie
Yep.Quote:
Originally Posted by novaguy08
Those Ronal's looks ruddy awesome imo..
Does look nice on the Ronals mate but isn't the offset of them an issue ?
I would put these on it.
http://oneilcastro.com/temp/RS/BBS%20RS.jpg
Theyd keep up with the standard of the rest of the car.
Yeah, finding them in 5stud might be hard tho..Quote:
Originally Posted by Mazz
Sure they are around 40, so they really arnt great.. But are workable..Quote:
They do look awesome, but are very Vw Golf style..Quote:
Originally Posted by LEWI007
Just to keep up on this, i've dropped more bits off to be re-trimmed.
Ordered new pads, as one has been contaminated with Cv grease, hopping that's why it pulls a little to one side.
My equal length shafts getting some loving at the mo too ;)
New rear number plate has been ordered too, totally blank.
Spent the weekend doing little bits.
New CTS fitted, new arm and freshly painted dizzy cap, but its still missing and bogging down when cold.
Fitted sound deadening to my doors, so they have a nice solid sound. Cover the insides in a rust proofing wax stuff too.
Cut my air filter down abit more, trimmed my bumper "mouth" a little more to give more IC clearance. Bumpers now been all sanded down so it can be painted before billing.
Great mod, makes the panels sound a lot tighter and less like a tin shed. also helps reduce road noise too. :thumb:Quote:
did it to my Nova ages ago and was the best £25 I had spent
Yeah i like to do it, makes the doors sound thicker and nicer.
Question with the sliggishness & missing
Have you changed the leads?
Sluggishness will be down to the lack of phase 2 chips ;)
At the mo no, i changed the king lead, as the prob started when i messed with it.
Maybe Si, if it only the fpg i'd need to upgrade when doing it?
Sh*t!! Just won a set of brand new seat runner covers, £27quid.
Change the leads Benn.
The coil ok Benn? check the insulation for any damage or cracks.
You got the hot start valve plumbed in?
Cant even see the coil, some one hide it quite well..lolQuote:
Originally Posted by Nova_Tek
Its plugged in, but not connected. But the engines fine when hot...Quote:
turnies ftw
Not cheap tho, not sure if they'll look right either..
plug gaps ????
Ah yeah got some NKG plugs from work, pregapped(0.7) and all 4 where almost dead on that. One was 0.6ish..
But i haven't fitted them yet.
bin them and run some rs turbo ones gapped to 0.7-0.6 mm :)
On a std let?
yup running rs turbo plugs in mine benn. been in there for bout 7 months now a no probs at all. and they'vebeen hammered to hell and backlolQuote:
i always take them out every month or so and re check the gaps and carefully clean the tips:thumb:
yeh rs turbo ones are the daddy's!
£4 i pay per set
I have them in my 1600XE. For the money & recommendations around the web, WIN!
£4? For Four? Serious?
