They are at wing level now....Quote:
i was carrying a bacon and egg roll aswell lol.
Some very good points you make there Olly and I should be up on power and down on weight compared to your old car :D :thumb:Quote:
As Olly said i am already aware of this...my saloon is lower that that atm so i am fully aware of the issues surrounding drive shaft angle etc and will be trying to address this issue....Quote:
Sounds good but TBH i dont see where the idea that low = good for a track car? To a point imho but if you want to run that low the you need to do as olly says and change the lower pivot placement, raise rack etc. Would be easier to cut the front off and space frame it all imho, then you would end up with ideal suspension geometry for what you are seaming to want to achieve?
I realize you have done the turret mod for suspension travel (where as i got custom shocks). That was the highest i could physically run my car, it also had the sump around 2" off the floor.
I would guess you are looking towards a dry sump, shallower bell housing, raising the diff up (seen the sequential box mentioned).
Not really as it can end up been at the expense of droop which is also as important as travel.Quote:
I had a faulty coil pack and standard box, you know that Mr Hewitt, you know that! :mad:Quote:
lollollol
+1 rep james awesome work, did i hear the word sequential? what a car this is going to be
As said before i'm not going super low and i have already raised the rack.Quote:
As you said i will be 'looking towards a dry sump, shallower bell housing, and raising the diff' all in the future as im not money money atm :thumb:
Do you know if a shallower bell housing is available?
like this prehaps?Quote:
http://i127.photobucket.com/albums/p...DSC05258-1.jpg
http://i127.photobucket.com/albums/p...DSC05255-1.jpg
