Zeifer, I only use a Cossie external pump due to the fuel pressue I'm running, a Nova GTE/ GSi & LET pump kept giving up.
I run 4.5bar / 62psi, which is quite high :thumb:
62 psi??? why is that?Quote:
im running throttle bodies and only on 50psi ?
It depends on the injectors/map your using.
You could run 3bar if you want, if the injectors were suitalbe sized and the ecu mapped to suit.
V. high pressure usually means your using quite small injectors, ehence needing more pressure to deliver more fuel
Plumbing should be done like the diagram below, not everyone chooses to run a filter before the high pressure pump though.
http://www.sbdev.co.uk/Info_sheets/F..._swirl_pot.gif
I see, i didnt even think the small peco injectors wanted that sorta pressure, cheers for the explanation :thumb:Quote:
Originally Posted by Adam
Olly uses standard XE creams :thumb:
thought it was blues he was useing as they have a better spray pattern 4 holes! as appose to the creams with have one HUGE hole and blues i believe are a slightly larger cc/min than creams
Defo creams...
i was just going by this thats all my bad he has obviously changed them for creams! :thumb:
he has indeed.....
changed em for creams because the blues sucked ass! :D
ah i see like i said my mistake not sure where he got peco's from anyway!
as I've not even been in the garage since I rolled the Nova in there after the last Donny trackday on 09-11-08, and it was soaking wet when it went in...
what are the chances that when I get it out on sunday morning it'll be a pile of rust? lol
especially on the bare metal bits from the bump lol
You'll have a carpet tho.....
Nice fury mould.
lol its going to be soooooooo minging
will smell of damp n mould! remind me NOT to ask for a passenger lap on sunday! lol
Yeah but nice under foot...lolQuote:
it'll be reet, my garage is heated so it'd have dried out by now.
i'll get her out on Saturday and see how it looks lol
I happen to like it that way mmmm stinky
I bet you have washed it already lolQuote:
check you out with your heated garage!*
*nonce
lol
So true lol
well, its not heated lol but it does have a draught excluder on the door. poxy single brick thick too :(
yup, pile o rust it is then
Where did you get your rear springs from? I have a saloon and im looking to do the same sort of rear spring setup you have. Also how did you go about getting all unwanted metal off i.e. the bonnet strengthening? Cheers
Mr Grinder is your friend when it comes to removing unwanted metal :DQuote:
Originally Posted by nathnova
rear springs came from Faulkners :thumb:
what the hell you changing too now?
who me? I'm not... the guy asked where my 4" 450lb rear springs were from lol
dum de dum, i'm gonna roll car out of the garage tomorrow to see if she still starts :D lol
will take pics, just because lol
good lad!
Tires are somehow stop model of Vauxhall? Where can I get some?
Sorry Zeifer, I don't understand your question?
Are you asking what tyres I run and where can you get some?
still not looked at Nova, however I do beleive it still has the 6" orange motorsport gaffer tape holding front of bonnet down, and the rear window in lol
oly, what happened to them light weight mirrors you had? you not using them now?
ste
I sold them mate, I felt they were way too small to be safe on track, especially considering I never run an interior mirror either :)
lol so all ready for tomorrow then olz ,
i cant show my face now , got to work but 8 hours at double time cant be sniffed at lol
No, I mean that which is the model they belong to the wheel cessaro? and where they could get, because I can not find some wheels 6j15 by any measure in hand, I have tried so far 7j15 and is too big for my car.
Maybe worth going for a check later on... make sure batts not flat or anything???Quote:
Zeifer - the Cesaro wheels can be found on MK3 Astra (Astra F), Cavailers (Vectra A) and some Calibras. Hope this helps mate, sorry for not understanding the first time around :thumb:
Rexy - gutted you're not showing your ugly mug, you promised me a hug aswell :(
Adam - I'll check later on, we have James 'The Count' and Danni stopping tonight, so will make sure it still rolls, tyre pressures, battery etc tonight :thumb: can't bare to go out in this weather to be honest lol
And youve got a garage ffs lol lolQuote:
