How much you looking to spend on a full car Colin either ex let or whatever? As I often come across them as I spend hours searching the net but don't have the money to buy them myself lol but I'm sure your budget is better than mine
Don't assume that!
If anything I'd prefer to buy a full car, so I know I have everything to get it going, and also I can recoup some money on selling off the rest of the thing in pieces.
But if I was just to buy a complete, ready to install engine, I could probably stretch to £1000, possibly a touch more. And I could part-exchange Nova parts into the deal if that was appropriate.
So I haven't got a lot to cash to work with.
Don't know if you'd be interested but there's a corsa c z20leh on Ebay cheap at the mo think it's up to £1750
At last, the Nova has a new home.
This was the garage as at 18th December;
http://i285.photobucket.com/albums/l...ps6b4658ba.jpg
http://i285.photobucket.com/albums/l...psd8783dcf.jpg
And then on the 19th December;
http://i285.photobucket.com/albums/l...ps0d641014.jpg
http://i285.photobucket.com/albums/l...ps71ffed88.jpg
And then this morning it was time to move the Nova in from its resting place on the patio;
http://i285.photobucket.com/albums/l...ps6f3b2a80.jpg
http://i285.photobucket.com/albums/l...psda1a43f4.jpg
http://i285.photobucket.com/albums/l...ps8891dacc.jpg
The 'new' garage, looking rather busy already, and it's only had a floor for a week or so;
http://i285.photobucket.com/albums/l...pse23c69fc.jpg
http://i285.photobucket.com/albums/l...ps255e36a8.jpg
http://i285.photobucket.com/albums/l...ps5bf3dec7.jpg
I need more space, already;
http://i285.photobucket.com/albums/l...ps127a1bc3.jpg
Look at that sexy 4th engine mount.
Y U NO PAINT FLOOR?
nice work cant wait to see more progress, what shafts are you running for the wide arch setup?
Awesome work pal garage floor looks good
a ok, what offset and width are they wheels?
ok thanks
Garage looks great, wish i had that space.
I've just picked up a Corsa bias pedal box from Jezz (Toymex), which will hopefully solve my issues with lack of legroom caused by the original floor mounted pedal box I had.
Further details to follow, and additional thanks to Simon (STT) who has sent me loads of details regarding modifications to the Corsa B pedal box which can be used in place of the Nova one.
If this set-up sorts things out, all I then have to do is adapt the clutch pedal to actuate a hydraulic master cylinder (as I'm on a hydraulic clutch system).
My garage is looking full. I sold a lot, then filled it up with more stuff...........note the Alfa 33 race car I have recently acquired;
http://i285.photobucket.com/albums/l...ps991d32f9.jpg
http://i285.photobucket.com/albums/l...ps70f5632f.jpg
http://i285.photobucket.com/albums/l...ps2f572822.jpg
I've also bought a 1400 Tigra, as I am going to fit my Nova with a smallblock XE engine, fitted with Jenvey throttle bodies and an MBE ECU/loom. As there's currently no way I can afford to get my 1.0 turbo engine rebuilt, the 1400cc 16v engine is the cheapest way to get my car back out racing (now over 18 months since it last raced).
http://i285.photobucket.com/albums/l...ps87944665.jpg
http://i285.photobucket.com/albums/l...psdd69a39a.jpg
http://i285.photobucket.com/albums/l...ps47167fca.jpg
Throttle body kit waiting;
http://i285.photobucket.com/albums/l...psd1d57590.jpg
Good plan buying the tigra.
I so want the alfa. One of my biggest regrets getting rid of my 33 especially as it was a green cloverleaf
The mock-up engine was removed yesterday;
http://i285.photobucket.com/albums/l...psa5f94f0d.jpg
http://i285.photobucket.com/albums/l...psa7353732.jpg
And the smallblock XE engine I'm going to use will soon be ready to go in;
http://i285.photobucket.com/albums/l...ps9e0f9f47.jpg
http://i285.photobucket.com/albums/l...psbd144ecf.jpg
I'm going to paint the engine bay today so it's grey again.
Got a bit more done this weekend.
Spaceframe re-painted;
http://i285.photobucket.com/albums/l...ps98d7a288.jpg
Started work on fitting the new front brakes, requiring new caliper mounting brackets. I've got one side finished now, and just need to make a mirror image for the other side. I've done them in steel for the moment, but once they've been tested and proved I will get the brackets re-made in alloy;
http://i285.photobucket.com/albums/l...psf5feaa46.jpg
http://i285.photobucket.com/albums/l...ps6510881d.jpg
http://i285.photobucket.com/albums/l...ps51b12988.jpg
And after lots of thought, and buying several different pedal boxes, I've decided to use a (Classic) Mini pedal box. I've started the fabrication and it looks like it should work pretty well. The Mini pedal box is nice and lightweight, and has a hydraulic clutch pedal as standard. The master cylinders are going to sit in the battery tray area, it's going to be tight for clearance against the bulkhead panel by the look of things;
http://i285.photobucket.com/albums/l...psad350e01.jpg
http://i285.photobucket.com/albums/l...ps8b578913.jpg
http://i285.photobucket.com/albums/l...psdd10d9d5.jpg
http://i285.photobucket.com/albums/l...ps4ff59d31.jpg
http://i285.photobucket.com/albums/l...ps1ca65351.jpg
http://i285.photobucket.com/albums/l...psee28c473.jpg
Good work, must be a first for the mini pedal box too? Start a trend? Lol
I used an escort pedal box; more metal to it though & extra weight over what you have there.
BTW Colin do you have a nova steering coupling lying around?
why the change from floor mounted?
Assuming you can't move the seat any further back, then you have 2 solutions as far as I can see;
1. Cut out and box the bulkhead to accommodate the master cylinders (see the Project thread that 8valve-Craig has done for his Nova to see this). I'm not allowed to cut the bulkhead in this fashion under the Regulations I race to.
2. Use a floor-mounted pedal box which reverse-mounts the master cylinders (i.e. they sit in front of the pedals). The problem I see with this is that you need a false floorpan to cover the cylinders, and obviously your feet are then raised up. Can't say I've ever seen one of these pedal boxes in a Nova, but I would be interested to have a try in one.
I use an OBP floor mounted box in my Belmont V8 Thundersaloon. That has reverse mounted master cylinders, and requires a false floor. Took a bit of getting used to as my feet are something like 4-5" higher than they were with the old Gp.4 Escort pedal box that I used to use.
Being a Thundersaloon and built for two/multi-driver races, the seat is on runners, and I have to run it almost right back. That also meant running a longer/extended steering column, and all the issues that go with that. I still have lots more to sort in that area - going to fabricate a new column at some point to replace the "spear" (as on series organiser calls it) that I currently have.
I can certainly recommend the OBP pedal boxes. Very good - beware of fakes/imitations though -it seems that there are cheap (and poor) Chinese copies appearing in the market.
They do a wide range of bulkhead mount ones too.
Here's a link to eBay.... looky and see...
http://www.ebay.co.uk/itm/Escort-Mk2...-/230859697441
Mine had hydraulic clutch too, but on a Nova/Corsa you'll be wanting the cable variety I'll guess....
Having just re-read your post Jake, I don't have any pics of it in situ. It's a case of offering it up to where you want it, then bolting it in position. To get the best position it's a two-man-job and if you can, do it with the dash out so you can see what you're doing.
I used a Mk4 Astra 1.4 16v belt I think, as they're electric PAS. So no pump.
Still working on the brake system, took a couple of photos of the proposed pedal box (Mini) actually fitted in a Mini - the hillclimb car of a friend;
http://i285.photobucket.com/albums/l...ps2f85b971.jpg
http://i285.photobucket.com/albums/l...ps000fa8d9.jpg
I'm not 100% convinced as to whether this is the answer, and I've recently spotted this rather impressive looking newly released pedal box, which is designed to suit sloping floorplans, and may gain me the extra legroom I need;
http://i285.photobucket.com/albums/l...ps1fe32ac6.png
I'll do some measuring today.
Meanwhile after a huge amount of Google-time, I found some rear brake discs which should be perfect, and at 300g each, lighter, and better looking too;
http://i285.photobucket.com/albums/l...ps918a6189.jpg
http://i285.photobucket.com/albums/l...psef79cabf.jpg
http://i285.photobucket.com/albums/l...pscb418df8.jpg
http://i285.photobucket.com/albums/l...ps72657316.jpg
http://i285.photobucket.com/albums/l...psf6c7ebff.jpg
I shall be ordering the new rear calipers from the USA today, they're not available on the shelf in the UK;
http://i285.photobucket.com/albums/l...psc90c7aaf.jpg
Really nice brake set up matey
Be interesting to see what your thoughts are on the power output on the x14
Those hubs are beautiful. Bike caliper?
The hubs are KAD (Kent Auto Developments) for a Mini. I modified the stub axle to allow them to fit, and it means I have 101.6mm PCD on the back. One day I have a plan to modify the front hubs so I can have the same PCD all round to make life easier.
The calipers are sold mostly for Karting, but they also use them on Junior Dragsters apparently.
Ah, so you'd have to run two different wheels then, that would be a pita. And Karting calipers... Very cool, i guess they'll give just enough effort.
