Originally Posted by
BRoadGhost
Looking bombproof Gareth. I would make the push to hydraulic release though; find an old vectra or similar to beef the top ally bleed union & pipe, maybe the slave cylinder too.
If not buy a new one for about £90, the part number is CSC007 for a QH or Equiv is MSC007 for the C20XE.
When you do get round to doing the pedal box, you want a 0.75 master cylinder. Be careful when bleeding & welding in something to limit the clutch pedal travel as if you let it go too much you will burst the slave cylinder; gearbox off again & another £90... Lee303 & the Topgear boffins that built the green MK2 escort 2L for Clarksons track day fell into this trap.
Best way is to have someone under the car watching it push as you gradually depress the pedal, then when it reaches full travel, mark where the pedal is to weld in some sort of physical stop.
