chris- ill be there from about 11ish tommorow..
martin- pm'd. Yep ill give it another go tommorow - its pretty straight forward, we'll sort it.
Glad its inspired; good to here your getting a result with yours - keep us posted :-)
*wee update..
Exhaust sorted; soo relieved.. no more headaches/can think straight/fumes in toxicating..
It runs badly; like its running on 3.. couldnt drive it over 20mph..
Originally since getting it to fire up u just couldnt tell what was going on as it was so loud so..
With the exhaust sorting its audible now ill post vids over the weekend, but need to look into electrics..
My fuel pressure gauge finally turned up today so can check that to my hearts content lol
Did you set the body balances??
That will make it feel like its running on 2/3
really? ok..
no we didnt lol
Makes a massive difference mate, even mine was lumpy like that on base map etc until Dar set the flow of each inlet body etc..
Good to see some progress.
Hi Dave
Good to see you got exhaust done.
Here is link to SBD saying how to balance throttle bodies
http://www.sbdev.co.uk/Info_sheets/M..._procedure.htm
If you need synchrometer again you know where i am
Martin
Did you drive it down to Phil then Dave?
Even though you couldn't go over 20mph, i bet it was still nice to get back the wheel of it!
awsome work! the cav slabs look spot on
Yes mate because one cylinder might be on 20% throttle and the other 3 might be 50% throttle..... (big exageration, but you get the idea)Quote:
Originally Posted by peester
So its bound to run rough with them not balanced :thumb:
chris: yep i did drive there , made it just, with many heads turning such was the racket of a blue nova going 20mph.. and back again ,much better as it sounded more normal.. but still only 20mph-odd.. wanted to film the way back but forgot.
ok ad, ill check it out when i can, thanks again chaps
