smooooooooooooooooooooooth operator ......
Handles will look the nuts.
Loving the fact New style audi have gone for a nova operating style handle lol
Cheers Chris,
Connor, made it easier this time.
Got all the insides cleaned up and sanded off, stripped all the sealant off the bottom join, rust treated as a just in case and have re sealed the join. Doors are now both all ready for primer.
Are these doors not painted yet!................ only joking fella Im sure they'll look well when fitted. Did you get some post today by the way? ;)
Nick.
Primer and paint Monday dude.. Cant fit them to the weekend so.. And yeah have it here is very pretty.
Handles are coming on Benn.
What else from other cars are you adding to the project?
Cav heated rear screen button now does my heated front screen... Erm
i had alod skool audi 90 handles in mine and they looked the nuts good work mofoQuote:
nice mate will be interesting to see how the handles look!!
Once the doors are painted and put on the car, the Nova should handle well... ba dum tish lol
I'll get my coat!
Ah cool, i just wanted the upto date, little less done style. Thank you too.Quote:
Originally Posted by GRUNT 16V
Me too...lolQuote:
Originally Posted by dj_wudgey
Oh...:tard:Quote:
Originally Posted by Nova_Tek
Now have a new Mot too.. Found out that full lock + reversing out of Craig's garage + lowness = Dent/ripple in wing, when the tyre tries to pull the wing lip in.. Oops.
Big thanks to Craig for the mot too.
Benn, what fan have you used on your rad ? How did you mount it ? Using the mounts on the rad ?
I have the same rad and need to sort a fan.
I run 2x 7inch fans on the front, using the fitting kits they come with. The plastic legs you push thru the rad with a teethed grippy washer thing on the other side (if that makes sence)
Will you hgave it in the bay? Or hidden on the front? If its out of sigh then i'd use a mk4 astra AC fan, they are the best fans i've used. It will cool the rad from middle (95) down to in the blue with in 5sec (i had it on mine when it was xe powered) Best fan. Ad now uses one too after i told him too..lol
I was thinking of having it on the front, looks more tidy there.
Where did you get your fans from ? Same place on eBay you got the rad from?
Do it, really cleans the bay up. Get a mk4 Astra fan, take off the outer trim and power block, you can cable tide it on and it will be the best fan ever!
Yes he sells them.. But i got mine for another site, where about £45 ish each.
Would like bigger ones, but i have no room with the IC.
Just looking for some myself :)Quote:
Originally Posted by Edd
http://cgi.ebay.co.uk/Slim-Line-Radi...item3ca9d1e064
That's them^
So get a mk4 astra a/c fan and use that kit to fit it ?
Or is that kit only to be used with the fans that you have got ?
Save the cash and two 4 cable ties. And yes mk4 Astra ac fan. Remove part of and trim the covers it has, mount on front. I'll see if i have any pics of mine.
Great find, I was looking for them aswell. Was gonna buy some from Jbimotorsport on ebay iirc but they're like a fiver or something. 1.30 with free p&p lol bargain :thumb:Quote:
Originally Posted by Mazz
i like the idea of a mk4 ac fan, do they wire in just the same as a normal rad fan?
Yes, 2wires. You'll need to remove the speed control block bit, but you can remove it with the outer casing, as its on that.
When's the doors going on Benn? have they been sprayed yet?
I finished off prepping the insides and sealing the welds up, hopping for primer tomoz and paint Friday.
Cool, me can't wait :)
Same, be handy as it means i have the 3day weekend to put it all back together and flat and polish them up.
ah a long weekend on the Nova....does it get better...lol
lol yes not working on it and just driving the **** out of it.
lol can't remember that last time I drove mine......
Crack on then, its dry.. That means Nova weather.
lol ain't dry here..
Is/was/will be. Get cracking.
Too many excuses and not enough time....Did I mention the diff blew on my daily earlier? lol
lol oops, oo did you have a part number for them hoses?
did you check my thread? lol
Erm.... *goes to look*
So whats been happening here then? You taken off your skirt & put on your trousers and fitted P2 chips yet?? :p
lol not yet, when the heads swapped it will have an Xe inlet cam.. Is that a ok start?
TBH all the audi toss pots should be putting the brilliant nova handles on theirs!
lol maybe a new craze we'll see.
Have ordered new front braided lines, as the ones i have are way to long.
