is there enough room between the turbo t0 fit the servo if not you could do the corsa pedal box mod
Not sure if i will be running the cossie servo/pump or if i will run cylindersQuote:
Originally Posted by dan23
Beast :thumb:
why make it a van though?
I had no say in that vauxhall did that bit :D I was looking for a nova and this van came up at the right priceQuote:
Awesome stuff, keep up the good work. Will you be making videos for us to see when its up and running?
Hadnt really thought about it. But if your wanting to see one then im sure i can do one for you. Engine should be going in the next couple of weeks im sure :thumb:Quote:
Originally Posted by paul james
0o0o0o0o i have gone week..
Well done dude
Loving the shot of the car with the wide arches on next to a standard arch nova, really wide ! these are the magnum motorsport arches yes ? where they join on the quarter panel under the window did you just smooth them in with a skim of filler ? did you rivet them on or bond ?
Yes the arches are from magnumQuote:
Originally Posted by DW-Nova
I cut them down so i can skim them into the first swedge line thought that would be easier
As for the fitting i lined them up drilled some holes ready to rivet them then added the bonding to the arches where they meet the body and then fitted it up with the rivets left for a fue days to set then drilled out the heads of the rivits to catty the quarters up.
I will dig out some pics of where i cut them down to if that helps
