Real heroes use these...........
http://t1.gstatic.com/images?q=tbn:A...WsFf8NXRjNB1US
Squirts in a /\ fashion straight onto/past the butterfly. I found that out when I took mine apart while it was running.Quote:
Originally Posted by MK999
Indeed, must be a fire hazard! Direct injection only pleaselol
A 1.2 spi will pass an mot and even trackday scrutineering with it's setup,
I very much doubt that external injection would pass either,
You better get onto the F1 teams sharpish then because the first race of the season is coming up! lolQuote:
Originally Posted by bazil
taken from FIA regulations,Quote:
5.8.1 The pressure of the fuel supplied to the injectors may not exceed 100 bar. Sensors must be fitted which directly measure the pressure of the fuel supplied to the injectors, these signals must be supplied to the FIA data logger.
5.8.2 Only one fuel injector per cylinder is permitted which must inject directly into the side or the top of the inlet port.
Lol I like....Quote:
Originally Posted by wwmnw
I don't know where it came from, but, we call them whale cocks!
I've seen 5th injectors on FIA approved cars....Quote:
Edit- what the hell is external injection anyway?!
and the ones from the F1 testing vid fire directly into the top of the inlet port, so?Quote:
Generally F1 cars have 8, db lol
Good idea for water injection I think...
but in this case MAD! :)
