Just taking full loom out now but how much of it can i get rid of ? its for track car so just need enough for it to run,
i had to use the full engine loom, here is a picture of my x16xel loom
http://i421.photobucket.com/albums/p...vengine006.jpg
wats the vss and where should it be located on the doner car
vehicle speed sensor screws into the gearbox where the speedo cable goes, thr cable then screws in on top of it
it has 3 wires on it 1+ 1 earth and 1 signal wire im sure
oh dear, mine doesnt have a speed sensor on the box, just has a litle blanking plate. Should it still work it i just dont connect the vss wires up.
You'll probably find it'll try to stall at junctions without the VSS.
Rite so this is where i am with the wiring. Iv connected some of it in, and i have crossed some wires off that im hopin i wont need. Will it still work without these wires connected.
I cant try it yet as i dont have the pump and tank yet. Many thanks for help.
http://img148.imageshack.us/img148/6739/loomedit.jpg
By boomtings1 at 2011-07-02
You need the VSS else the car will stall everytime you slow right down, and it means it can run rough sometimes. You will want the EML working if you have any issues, its only one wire, connect it! and why arent you wanting a rev counter?
Im only wanting to kno if will work like this for now as i dont have an EML VSS or a rev counter
Just a quick one but what do i connect the coolant temp wire upto? Its the thick blue one from the dash cluster. I dont have the standard ECU mind, its a DTA s40. I presume i can't just connect this into the ECU's sensor as its a twin wire CTS on the C16XE?
Phaser how have you connected your temp sensor?
