With the engine rebuild it was then time to wrap and fit the manifold..
https://fbcdn-sphotos-d-a.akamaihd.n...93264149_o.jpg
https://scontent-lhr.xx.fbcdn.net/hp...29943122_o.jpg
I then took my gearbox over to a friend who swapped the gear cluster for an F13CR one (as it has the removeable pinion gear), fitted my Quaife ATB and fitted a new crownwheel and pinion to make the FD 4.18.
https://scontent-lhr.xx.fbcdn.net/hp...15996136_o.jpg
https://scontent-lhr.xx.fbcdn.net/hp...71727485_o.jpg
It was then time to get the Nova out of hiding and towed to my work ready for the engine fitment. But before that, it would have been rude not to get pictures of two broken rot box Vauxhalls lol
https://scontent-lhr.xx.fbcdn.net/hp...55680412_o.jpg
https://fbcdn-sphotos-d-a.akamaihd.n...59606116_o.jpg
Got the Nova to work and onto the ramp. First job was to fit the new Corsa 2.7 turn rack with poly mounts...
https://scontent-lhr.xx.fbcdn.net/hp...32807591_o.jpg
https://fbcdn-sphotos-c-a.akamaihd.n...84665633_o.jpg
https://fbcdn-sphotos-e-a.akamaihd.n...53466354_o.jpg
Then the cambelt was fitted to the engine along with the bottom inlet and a couple more bits and pieces...
https://fbcdn-sphotos-f-a.akamaihd.n...25971277_o.jpg
https://scontent-lhr.xx.fbcdn.net/hp...86248450_o.jpg
https://fbcdn-sphotos-h-a.akamaihd.n...92730480_o.jpg
I painted up the new Dbilas inlet using VHT wrinkle paint..
https://scontent-lhr.xx.fbcdn.net/hp...64055177_o.jpg
I spent a little bit of time tidying bits up and refitted the scuttle cover along with a couple of complementary stickers..
https://scontent-lhr.xx.fbcdn.net/hp...21018875_o.jpg
https://scontent-lhr.xx.fbcdn.net/hp...80780201_o.jpg
https://scontent-lhr.xx.fbcdn.net/hp...18794676_o.jpg
6 point harnesses crutch strap added to drivers harness..
https://fbcdn-sphotos-c-a.akamaihd.n...15354530_o.jpg
I finally managed to get my Cavalier rear ARB fitted too. Excuse the mess underneath, it was very wet and dirty on the roads before it came off the road!
https://fbcdn-sphotos-d-a.akamaihd.n...19694610_o.jpg
Now for the part I kept a secret from everyone for quite a while. Ever since I've had the engine conversion, it's always missed that 'special touch'. I had stumbled across the perfect private plate about 1.5 years ago and ever since wanted it for the Nova. Fortunately, it was still available and I felt it was the perfect time to purchase it..
So, welcome everyone to C16XE X....
https://scontent-lhr.xx.fbcdn.net/hp...40645131_o.jpg
https://fbcdn-sphotos-b-a.akamaihd.n...42039060_o.jpg
https://scontent-lhr.xx.fbcdn.net/hp...76433404_o.jpg
As everything was now back together and it was all legal for the road, I gave it a jetwash and took it out for a long drive to run the engine in..
https://fbcdn-sphotos-e-a.akamaihd.n...16251124_o.jpg
https://fbcdn-sphotos-g-a.akamaihd.n...43812044_o.jpg
https://scontent-lhr.xx.fbcdn.net/hp...54690576_o.jpg
Within 4 days, 500 'running in' miles were completed and the old girl never missed a beat.
As I had to do an oil and filter change I thought it would be the perfect time to fit my oil pressure and temperature senders using another sandwich plate. I also wired in and fitted the new gauges...
https://scontent-lhr.xx.fbcdn.net/hp...99113197_o.jpg
https://fbcdn-sphotos-f-a.akamaihd.n...62026552_o.jpg
https://fbcdn-sphotos-b-a.akamaihd.n...17886733_o.jpg
https://scontent-lhr.xx.fbcdn.net/hp...39440337_o.jpg
Here's just a couple of pictures from running it in until now..
https://fbcdn-sphotos-d-a.akamaihd.n...64572151_o.jpg
https://fbcdn-sphotos-b-a.akamaihd.n...83945653_o.jpg
https://scontent-lhr.xx.fbcdn.net/hp...22048635_o.jpg
As I mentioned earlier, the Nova never missed a bit until the other day. As you can read above, the 'hesitation' appeared back again. Beforehand this was due to the inlet manifold leaking air (I believe) because it was running too lean but this time it started running too rich.
I lost all motivation and decided to put the Nova away for a few days to have a rest and get some motivation back. I never managed to find the cause of this but decided to get it out and use it a couple of times. The hesitation slowly got worse until last night when I lost near on all power and was getting serious pinking/detonation.
I managed to limp it home where I eventually found that the crankshaft sensor plug had slowly worked its way loose (obviously over a week or two) until it completely lost contact last night. After refitting it, I took it out again and it drive like a dream, absolutely spot on. So much so it scared me to a certain extent! lol
But, in my hastily fashion, instead of just giving up I put a deposit down on an engine package. As posted above, this engine package included a set of Jenvey ITB's with MBE management. As I thought the hesitation problem was either ECU or wiring related, and the fact i've always wanted a set of ITB's this was the perfect excuse to just go ahead and do it.
So now the Nova is running perfectly and the fact it should be fitted with a set of Jenveys by PVS, my love for the old girl has grown strong again!
Thanks for reading this very long winded update. I really should try and update my thread as and when things happen really...
And the last picture i'll leave you with is the last I took when I put it away and questioned selling up....
https://scontent-lhr.xx.fbcdn.net/hp...55649226_o.jpg
Really glad you found the prob and have the love back. That's great news.
As said before i love the plate. Have you thought of a cut down plate to fit on the front bumper?
I have Ben, yes. But for this year i'm going with 'function over form' with the Nova. So i'll be swapping the front bumper at some point with my other one with holes cut to allow more air to get to the radiator.
That is also why I haven't had the engine bay sprayed like I wanted to. As I just want to get the Nova out and actually enjoy it, do a fair few track days, a trip to Nurburg etc.
Then, during the winter I'll spend a bit of time getting the bay sprayed along with the new doors (as the bottoms of the current ones are rusty) and generally just tidy it all up again.
Totally fair, i know the feeling of just wanting to drive the bloody thing.
Are you not putting the cambelt cover back on ? good work mate looks great :thumb:
Hi Liam. I would like to know what fan do you have fitted to your rad?
