Tried it to see what i thought in the dark!
If i chose to do all 4 wheels i would get new stickers & do them right! :)
stickers look ok but need a pic taken standing back to make my mind up
I think I would have gone for a darker grey as it would have contrasted better with the the jewel violet. However I wouldn't at all say they look out of place. The stickers are hard to place as the spokes are slimmer towards the outer edges and are curved which gives the impression their wonky when their actually not I know that back from when I fitted them to hua. New stickers are available cheap on eBay though Martin in a variety of colours.
Nick
I like the stickers if done right, adds small detail!
Howdee,
Been tatting in the garage Saturday morning fitting my new SBD nylon pressure relief valve to overcome the issue of the standard one sticking.
Had it from Nova-Tek a forum member on here.
According to the distructions the oil pressure seems about right. Couldnt hold it at 4k & take a picture! :)
http://i12.photobucket.com/albums/a2...V/P1010715.jpg
http://i12.photobucket.com/albums/a2...V/P1010717.jpg
Arrived today from Gaz, my rear shocks i sent them to have the bottom bushing replaced to a spherical bearing.
Really pleased with them. Look like new! They replaced the bearing obviously that i asked them to then also the spring cups, top & bottom and new top rubber bushes and all re galvanised to look like brand new. Cost of £70.00 for the pair and including the p+p which i think aint bad.
http://i12.photobucket.com/albums/a2...V/P1010723.jpg
http://i12.photobucket.com/albums/a2...V/P1010721.jpg
http://i12.photobucket.com/albums/a2...V/P1010722.jpg
Just got to make them fit now :)
Total width where the shock mounts to the beam is 33mm & these with the spacers either side of the bearing are 36mm, so will take the spacers to a engineering company we use at work tomorrow & see if they can turn a few mm of for me.
Hopefully by the end of the week it will be back on all 4 wheels & ready for some road tax! :)
Martin
good stuff martin, oil relief valve going to be a fiddly fit?
Christ that's good work from Gaz.
Nice to see the relief valve is doing a good job. Most have the time revving over 2k will get you the max pressure anyway but 65 psi is 4.5 bar.
coilovers look like new! that pump is doing good pressure now too!
Was of work this afternoon so had a few hours on the Nova.
I have had the cone spacers either side of the rose joint turned down by a local engineering company so they fitted into the mount so this afternoon was put it back together.
http://i12.photobucket.com/albums/a2...V/P1010724.jpg
http://i12.photobucket.com/albums/a2...V/P1010728.jpg
Still need to look at the ride height so its sitting level.
Then dragged it into the sun for a snap & have a look at the wheel colour.
http://i12.photobucket.com/albums/a2...V/P1010732.jpg
http://i12.photobucket.com/albums/a2...V/P1010735.jpg
Just need to decide on if to have the stickers on the wheels or not.
Took it for a quick run around the block then back into the garage under its cover.
Martin
