lol
lol
Ref the steering wheel, I have a Corsa Epas system to go in and will be extending the column 'oval race' style to suit the seating/pedal position. Also running a Quaife internal shifter so the handbrake needs to sod off elsewhere and the gear lever go in that position somewhere.
Get that tax sorted!
Bring it to pvs then?
Its good to see the car is coming along so nicely, presumably you've got your newly built engine in it, or have you? Come on spill the beans, I need a juicy engine rebuild fix...
On the pedal box front, I feel I ought to stick my oar in because seemingly that is what I do. I notice the master cylinders lay over at an angle, a feature that is common to most of the floor mounted units. The problem as I see it is that in this configuration the outlet ports are not positioned at the top of the M/C bores, which means that air will remain in the M/C until such time as the cylinder is rotated to allow this admittedly minute amount of air to escape. This is somewhat exacerbated by the fact the cylinders are facing uphill with the outlet port at the bottom! Not good for pumping the air out of the system :cry:.
All is not lost however as I believe that one of the advantages of such an installation is that when the pedal is in the released position any air in the M/C will tend to migrate back out to the reservoir, however this will only happen if the M/C is in the upright (ports at the top) position.
So it might it not be worth releasing the M/Cs from the box and rotating them slightly anticlockwise to allow any minute amount air to work its way out? Could leave them in that position while you off slogging your guts out in some foreign clime :d. Hopefully you should have a solid pedal once you've re-affixed the M/Cs to the pedal box and them bled out the calipers, surely got to be worth a try?
Anyway I'll go away and get back in my box now...
Tax is being rolled tomorrow morning, cheap as chips!!!!
PVS booked my man!! Just not decided on drivin it there or trailering it!!!
Your input is always welcome Mr Tall. I can't rotate the cylinders, they're on fixed holes, I could tip the pedal box up I suppose but now that it seems to be working I'm inclined to leave it well alone!!! I do have to change the flexi lines to my proper ones so I'll be re-bleeding then!! Loads of fun!!!
Doesn't matter what orientation master cylinders are, for both service & operation; they should always be bled hydraulically.
A one man brake bleeding kit that takes the pressure from a road wheel can be bought new for less than £20.
~ There's quite a lot happening off that pedal box; are you not tempted to put an F18 hydraulic clutch slave on?
Mr Ghost, having looked at all the issues Lee303 had with leaking slaves I wanna stick with cable.
I've got 3 different one man bleed kits, none of which worked. The only way I could do it was by tubing the solid pipes back to the resoviour and pumping the pedal over and over. I would guess that now th system is air free I could use a pressure bleeder. I need to find one with a cap that fits OBP resoviours
MOT
http://i27.photobucket.com/albums/c1...000C7D3FDD.jpg
The only issue were rear brakes not working to well from the pedal but a little bias adjustment solved that and side repeaters not working, that needs a little investigation, which i'll do when I take the wings off to hide some cables
On to today,
Speed sensor mounting
http://i27.photobucket.com/albums/c1...4872B0D52C.jpg
Fully welded in place
http://i27.photobucket.com/albums/c1...BE43DE6C5B.jpg
Little vid of it working, taken on a private road.
http://vid27.photobucket.com/albums/...F1A5E36E08.mp4
This was the the biggest ballache ever, changing door pins, I did not enjoy it, so much so that the drivers one hasn't been done as it's not as bad!!!
http://i27.photobucket.com/albums/c1...C0F42CD0CA.jpg
Mate of mine is gonna polish it next week, ordering my Quaife LSD on 15th and hopfeully Iain and I are fitting it before the hit Cadwell on 26th, assuming Iain can sort his engine issues.
I can't wait to look round this !
