/\ lol
/\ lol
Have you driven it ben to see the difference?
Not yet, had to re route all my wiring that's in the arch. After repainting it. That's all done now...(Stainless Pclip, didn't notice the coverings come off the loom there tho, oil cooler lines have been 2way Pclipped up too)
http://img.photobucket.com/albums/v3...psgmksruop.jpg
Tracking it at the weekend as it will be toeing in like a mofo now. Then i'll test drive it and make a video too.
No time for sex tapes Benn, you need to save those wires from full lock rubage.
Checked that, that's why the thinner ones is a bit oddly run. It keeps it away from the tyre... I do want something to run them in tho. Will look better.
Plus i can't get anywhere near full lock!
Wanted to make my "air box" look a lil better, now this is only a plug really. I have a friend that does fiberglassing, so he'll gonna make me a Carbon fiber one. So i just need this to look and fit right then it can be copied.
So with the wing off i did a few mods to it to get it fitting right. Then stripped to fix.
Patton drawn to use as a fitting template.
http://img.photobucket.com/albums/v3...psbppfdq5a.jpg
Casing bits needed to be shaved as they stop it all sitting flush.
http://img.photobucket.com/albums/v3...psm1qlysoq.jpg
Trimmed a bit more off here and there.
http://img.photobucket.com/albums/v3...psjraggdio.jpg
A few spot welds if you will.
http://img.photobucket.com/albums/v3...psxtayhyg9.jpg
http://img.photobucket.com/albums/v3...psmrcfzavi.jpg
Then plastic welded it fully to be sealed and fit right. These will be smoothed before a mould is taken.
http://img.photobucket.com/albums/v3...pskfddimrj.jpg
http://img.photobucket.com/albums/v3...psq6e8gmcd.jpg
One last bit to add in for some strength and i can refit it. But my soldering gun got very hot, so had to stop. But will finish it tomoz and then refit.
Should be interesting with an airbox, will it be big enough and not suffocate the airflow would be my concern Ben.
Had the air box in there the whole time. Was just screwed together tho.
IT's totally open front the front so should be fine. It's just stopping anything being flicked up front the bottom/back really and to make it a little more water tight.
Nice progress Benn. I like it how you always find something to tinker with. :thumb:
