No mate, the cement stuff isn't rtv. It doesn't smell of vinegar (lol) it's the stuff used to glue sumps on, when there is no gasket. ie steel pan to alloy block etc.Quote:
It looks a tad thicker. I asked as those two fans look a decent size. I could go for 1 large fan but need to check out how much room I'd have left. The IC will probably be mounted slightly higher than normal due the the front being a snowplough so that will have some bearing on what size fan, inside or out and how large.Quote:
Oh that stuff, Fiat use it. If it comes it yeah i'll have a tube.Quote:
Originally Posted by John H
I'd rather have a bit bigger fans, but they work very well and keep the car happy. Cut the cross member and you can mount it as low as you want. Wish i had gone a bit lower, but its right in the mouth so gets good air flow.Quote:
Originally Posted by Nova_Tek
pm address. ;)
not really, an odd drop from time to time, but ive never noticed an affect on the oil level, it leaks feck all really. and mine spends most of its time running in the shed and no puddlelolQuote:
on another note, any other nova id be iffy on the bra, but on this i thinks it looks good:thumb:
It dont look pretty, but it's worked, i had small leaks all about the sump even after i replaced mine and put the short bolts in, and then i got small leaks from the cooler pipes and a bit at the back of the filter too, so i just got pissed off and smeared the sealant ALL over and joint! lolQuote:
Yeah see mines been in the garage since Sunday, and there's a puddle about 2inch wide under it. But the oil level don't go down ....Quote:
Originally Posted by alan b
Just done it. Cleaned it with brake cleaner then smeared it on over the joins all round and used my finger to even it out. Looks poo, but leaking looks worse.Quote:
Mine would drop a penny sized amount over a weekend, nothing for me to care or worry about. I could probably make it worse changing the gasket!
what size fans are they on you rad ben?
Oh right about the same as mine then.. Is just messy. Underside looks worse.. but keeps it protected..lolQuote:
As said about 7 times, they are twin 7inch.Quote:
Originally Posted by let_nova
Held a 4pot in place and can see why you need these discs with a huge off set...
Been trying to work out the discs for the 4pots. So measure everything get out the brake book...
http://i6.photobucket.com/albums/y23...n/IMG_8806.jpg
http://i6.photobucket.com/albums/y23...n/IMG_8807.jpg
Think i've found one that fits...
http://i6.photobucket.com/albums/y23...n/IMG_8808.jpg
Sadly this is as far as the can be fitted.. :(
http://i6.photobucket.com/albums/y23...n/IMG_8817.jpg
Ah can see why you need a huge offset on the discs..
http://i6.photobucket.com/albums/y23...n/IMG_8818.jpg
http://i6.photobucket.com/albums/y23...n/IMG_8819.jpg
Need to trim my hubs down tho then i can try fitting the discs
As the Rolling road is next weekend, the front needed to be raised up a little just incase..
Started off with 40mm of thread left showing..
http://i6.photobucket.com/albums/y23...n/IMG_8821.jpg
Wound it up a bit *vom* 50mm..
http://i6.photobucket.com/albums/y23...n/IMG_8823.jpg
After the RR i can wind it right down, haven't tested how low it will fully go.
Also i got all my interior bits back in too..
http://i6.photobucket.com/albums/y23...n/IMG_8812.jpg
http://i6.photobucket.com/albums/y23...n/IMG_8811.jpg
Got my new gear gator fitted too :) matches the seats...(black leather white stiching)
http://i6.photobucket.com/albums/y23...n/IMG_8815.jpg
Love the interior good work,
Poverty spec round knob!!
Did you ever fit the side mouldings for the seats I sold you Ben?
Round knob? What gear knob? What else would be fitted? IS a 4speed one too..lol And no haven't fitted them, but will soon.
Cheers 1992.
i want my car done, you make me sick lol
You love it. And get it finished and wheres my brace.... lol
your worse then a woman lol
Looks good!! Wheres the RR at?
Dj told you i hate having to wait, i burn my topunge alot too.
Ad:
JKM in portsmouth. Sbd rob had his Astra dynoed there and the figure was good so we thought we'd try them.
Interior looks very nice mate :)
Is it my imagination or can anyone els see what looks like blue/gray SR/SRi strips on the sun visors??
Aye looks like theyre rattle canned, might try that or cutting a section from an old GSi seat cloth and sticking it in place of the blue/grey i reckon.
Interior looking good Benn, needs another seat switch on the drivers side though lol
Cheers Novalovingned.
Scott, they are blue sr visors, you can only see the blue with the flash on. If you look at them, you cant only see the patten not the colour.
Spud, the center bit isn't in all the way. As i wasn't sure which way the window switches pluged in.. Took a guess and got it wrong. Have both buttons don't worry.
Really don't like the way it drives with the front raised up. Its really light and doesn't feel connected to the road right. Spun it up big time in 2nd and 3rd while playing with a new turbo Vw Scirocco.. Which was surprisingly fast.
It is possible to alter grip levels with ride heights, as you say raising it tips the grip the other way, I'm not sure of the exact mechanics or whether it's purely because you're effectively tipping the CoG a few mm/cm back!
Either way i don't like it!
Gonna wind then right down after the RR day.
Benn... how is your roof lining secured in place? Have you just retrimmed the lining in the same way it left the factory (held up by metal support bars) or have you directly stuck it to the roof skin and contoured it around the beams?Quote:
It look very tidy. The roof lining I did many years back has faded at the rear due to the Nova not having any tints in the glass. So I'm considering what to do and yours looks great.
Its a copy of the std one, so the bars hold it up. Then i've used spray glue on the edges where it holds around under the door rubber.
Mine has a sunroof so it couldn't be stuck to the roof.
Right gotcha. I was actually thinking about sticking mine to the skin and moulding it around the roof beams. Help to lose a bit of weight and probably be easier to clean. Mine has a sunroof too. I'd have thought some carefull trimming would sort that out.
If you didnt have a sunroof then yes you could just stick it straight to the roof.
Weight saving? It weights about 2pounds... The sunroof cassette is about 15kgs...
The sunroof cassette is foam covered, so glueing on that would be a ****. then you'd have to builds the sides up to meet the center too..
Sorry man, forgot to add that my sunroof is different though not a factory GM one :tard: . Mine was an aftermarket Solarsport sunroof jobbie. When you take the lining off you can see the full roof skin as you would with a non-sunroof car. But obviously there's a whole filled up by a sunroof.
Ah then yeah you could stick it straight to the roof, and shape it by hand over the lumps and bits.
Over the past years, I've been doing quite a few motorbike engine overhauls. Same problem with leaky sumps (yes even on Jap bikes). Most people try to overcome this using lots of cheapo silicone sealant or comparable stuff and doing up the sump bolts to the point where they nearly break. Doesn't always work.Quote:
Best cure against drippage is to (indeed) thoroughly clean all mating surfaces, use proper gaskets (not sure which ones are best for XE sumps) and tighten all sump bolts to the specified torque. And yes, a thin film of Würth Silikon Speciale 250 (German stuff) works a treat,
Hope this helps,
Niek
looking good matey i think the car bra looks well also!!
Cheers for the info.Quote:
Originally Posted by nova_niek
I made sure all the surfaces where ultra clean. And used all gen VX parts this time to see if it helped.
Cheers dude.Quote:
Originally Posted by dj_wudgey
Car in the garage washed and clayed. Gonna get a full buff up, polish and wax and then i can try my new sealant.
A big thank you to Dan for his help mocking everything up and a trail fitting on his GTE.
Now an even bigger thanks to Pete. Who spent this afternoon doing some machining for me.
So i turned up at Pete's house/Garage with all this..
http://i6.photobucket.com/albums/y23...n/IMG_8824.jpg
Pete started off getting the hubs stripped down.. Ooo look at this size of his spanner.. lol
http://i6.photobucket.com/albums/y23...n/IMG_8839.jpg
Bearing removal thingie.
http://i6.photobucket.com/albums/y23...n/IMG_8825.jpg
Needed a bit more grip.. Carefully does it!
http://i6.photobucket.com/albums/y23...n/IMG_8827.jpg
Now on to the fun bit.. Lathing.
http://i6.photobucket.com/albums/y23...n/IMG_8830.jpg
The outer of the hub needed about 2mm shaving off and about 4mm from the center (to make it all the size side, no step)
http://i6.photobucket.com/albums/y23...n/IMG_8835.jpg
Got my new disk to test fit.
http://i6.photobucket.com/albums/y23...n/IMG_8828.jpg
Looks like the kittie. As the disk is for Vag car it's got a few holes, lucky it lines up with the 5stud hub :)
http://i6.photobucket.com/albums/y23...n/IMG_8838.jpg
http://i6.photobucket.com/albums/y23...n/IMG_8840.jpg
Bit of mocking up..
http://i6.photobucket.com/albums/y23...n/IMG_8841.jpg
Oooooooo hello!
http://i6.photobucket.com/albums/y23...n/IMG_8842.jpg
Bit of a gap on the rear..
http://i6.photobucket.com/albums/y23...n/IMG_8844.jpg
Bit its a nice fit on the front :)
http://i6.photobucket.com/albums/y23...n/IMG_8845.jpg
Shame you cant see the name tho.. New wheels would sort that tho... ;) lol
http://i6.photobucket.com/albums/y23...n/IMG_8846.jpg
With that sorted, i know what i need to buy to finish(a small spacer and 10mm longer bolts)
Pete pressed the other hub and bearing out.
http://i6.photobucket.com/albums/y23...n/IMG_8848.jpg
Inner of the hub thats turned down to fit the Nova bearing.. All perfect after 5k of abuse.
http://i6.photobucket.com/albums/y23...n/IMG_8850.jpg
Screw buying disks from Rally Design.
Once again a huge thanks to Pete (pitstoppete)
Looking good Benn, No recent pics of Pete's Cav?
cracking results mate, why not buy some studs and nuts would make things much easier !
