Thought the engine mounts will be the same.. yeah but the nova driveshaft's will go into the box and corsa hubs?
You can use your nova shafts and your nova mounts and nova hubs.
But yeah the nova shafts will go into the Corsa hubs
You can use the legs
You can use the hubs and brakes
You'll need the nova shafts
You'll need the nova mounts, unsure if the rear gearbox mount is the same tho
It is the easiest way by getting a full car, so you know the engine runs and everythings there, you can also get the transponder loom out of the donor car too.
Ive got a full N reg, Corsa GSI, So stripping that and ive dropped everything out the bottom, ie. legs, coilovers, bottom arms, brakes... everything!
Cool, should be fairly easy then
Bottom arms are different as are the shafts
Ive dropped this little lot straight out the corsa, am i right in saying this is the c16xe?
http://i45.tinypic.com/ea2udf.jpg
The best way of telling usually is by the head, just under the rocker cover there will be 5 dimples that stand out, if all are even then they usually are C16xe's... If they're of different lengths then there usually a X16xe or X16xel
Will have a look tomorrow, Struggling to find a fuel tank and pump now! :(
Tank and pump here. PM me if still needed
The corsa b hubs, can go straight on the nova providing i use the nova shafts yes?
as ive left hubs and brakes as one
that is what i did daniel never had no problem
Using this... http://www.carbodypanels4u.co.uk/vau...rol-injection/
and
This would work?... http://www.ebay.co.uk/itm/Vauxhall-A...item3a7e21e755
Ive been told i can use the fuel lines that are already on my car?
Ive got my x16xe in and running, took it for a drive today, and the limiter seems to be really early? around 3.5k? :S
right ive been looking at this guide but is there a way to get round the speedo sensor (to stop it cutting out when i dip the clutch) so i can use a cable speedo
Yes, use a Nova 1.2 Spi speedo sensor. It has a cable but also the wires needed to stop it cutting out.
They are fitted on most corsa b to be fair. All the 8v should have them, some 16vs don't though
i picked up a af one from the scrappys today
hi all, just a quick question on the wiring stripping part.
when chopping the plugs off my standard ecu (1.4spi) and pulling them through to remove them from the car how do i split the rest of the loom for the headlights and everything? or is it literally seperate it all then re-wrap it?
thanks
that's what I did curtoise cut plugs removed all the wires then re-wraped what wires were left
is it quite easy then? im imagining spaghetti going everywhere lol
not to bad just took my time. with mine was a 1.2spi
Another quick question does the standard alternator belt clear the chassis? Does anyone have any pictures ?
This thread needs a clean up, needs all the information that's vital putting on page one, as it's a right ballach to search through..
