Aye it will be the same one as the SR's and Antibes etc Adam :)Quote:
So a gte one is different????
GTE one is the same except its painted...
Not sure if theres a difference in feeling though due to the SR's being rubber and the GTE's being painted
Cool, cheers
+rep
You must spread some Reputation around before giving it to vaughanmc again."
oh well, the thought was there lol
Glad I could help Adam
Cheers fella :thumb:
That PS on TH's fapping ace Matt!!
BTW, Ive now got a pic of those rear arch carpets you were after chap?
Ta!Quote:
Originally Posted by Mike
PM me the pic please fella :thumb:
Are you getting Th's then Matt?
Watch this space ;)
Shortened rear shocks matt? Rear springs come in the kit or are they coilsprings89 ones? How much if you don't mind me asking?Quote:
Originally Posted by Matt.
Do it :thumb: they look fapping ace on white motors :DQuote:
Theres a pic of those arch carpets in the for sale in a thread by me mate ;)
Nah, just the standard Gaz GHA kit. The springs are just the ones Gaz supply too. I'm pretty sure it's just a bog standard GHA kit but I got them second hand so can't be certain.Quote:
Originally Posted by John H
Cool, thanks matt.Quote:
Good lad, 6x14 with 195 45 14's.... :DQuote:
Funky topmounts on...
http://i242.photobucket.com/albums/f...t/7f78ab37.jpg
Bolted up again...
http://i242.photobucket.com/albums/f...t/a8ff34b9.jpg
Bosh...
http://i242.photobucket.com/albums/f...t/0d873b7d.jpg
Was gonna paint a few other bits and bobs and sort the calipers out but cba. Will get it all finished when I'm back again in a couple of weeks and then it'll be MOT time!
That top part of the damper doesn't seem to sticking out the top of the nut very far ? not as far as mine did ?
Maybe try them without those spacers ? Take the springs off then just bolt up the topmounts with the spring seat (black bit on top of the spring) and nip them up, if the black bit is clamped up then they'll be ok, if there still loose then you'll have to run with the spacers.
Mine where early GAZ shocks, later ones might be different ?
Aye, I did think about leaving the spacer off as they don't stick through far. Just stuck with them though. Will no doubt whip them off AGAIN next time and see what's what. Did the spacers slot over the slightly thicker part of the piston and sit on top of the spring seat on yours? They're not quite wide enough to do that mine and are just kinda loose before the weight of the car is put on them (seems dodgy).Quote:
Originally Posted by R1CH
Aye they sat on the wider part, were machined to fit perfectly, so if there not sitting right on yours then i'd take them.
Older ones are likely different to the newer ones.
Fairdoos, thought that would be the case.Quote:
nice matey loving the coilovers!!
This car is Stunning and will become one of the best on the circuit IMO,I Doff my hat to you sir, take a Bow
Wheels, id consider the new OldSkool re-issue flat face Mo's that Reyland have got in (Check them out thay are stunning and not on a nova yet) in 16"'s or go with something different other than the usual mo's TH's Sheeplines ect
Choose your wheels very carefully as they could really set this Car out from the crowd :thumb:
Looking good mate. How did you tighten the top mount nut? (seeing as you cant get to the piston flat)
Was just able to get an 8mm spanner to hold the flat whilst I did up the topmount nut. Didn't put it on really tight as I was pretty sure they'd have to come off again and the spacers taken out. They'll stick through alot more once I've done this.Quote:
simply stunning and what a find, keep up the good work.
my auntie had a nova ski years ago, she killed it though, shame!
check my project out, very diff to urs but take a look
as said on cwc,looks stunning that lad! i actually thought you were sumone else when you 1st posted it on there. 'hence my commet ' matt keep a car long' haha
keep up the good work, wouldnt mind a look at it at somepoint when you get it on the road mate!
that thing looks the absolute dogs balls
Cheers for all the comments!
Reece, I'll still have those calipers off you if you still have them? I'll be back again in 2 weeks so we'll sort it out then if thats ok?
nebother matt! just give me a shout when your back and we will sort it out,still got em like.
Good work matt! You've got to love the coolness of old school mk1's :thumb:
Got a couple of bits done today. Was expecting some calipers to be dropped off but the fella never turned up. Got my coilovers set up better, gonna get some spacers made up to stop any movement between the topmount and the spring seat though.
Anyway here's a few pics I took just for the sake of this thread...
Spacer that didn't quite fit so was removed (supposed to fit over the wider part and sit on the spring seat)...
http://i242.photobucket.com/albums/f...t/f8258255.jpg
How the topmounts are now...
http://i242.photobucket.com/albums/f...t/7a6f4ab5.jpg
Fitted up again. This time the piston flat sticks through nicely...
http://i242.photobucket.com/albums/f...t/042c2f42.jpg
http://i242.photobucket.com/albums/f...t/f6ecd26b.jpg
Both together...
http://i242.photobucket.com/albums/f...t/f0ecec9f.jpg
Got some period mudflaps this week...
http://i242.photobucket.com/albums/f...t/4163a89a.jpg
Turned the U-clamp on the exhaust the other way up as it was making a mess of my driveway lol ...
http://i242.photobucket.com/albums/f...t/c6e90db7.jpg
A crap pic in the sun, just trying to show the effect of the painted arches...
http://i242.photobucket.com/albums/f...t/51294c9c.jpg
And another one of it looking shiney in the sun (first time in fooking ages!)...
http://i242.photobucket.com/albums/f...t/d6cdd0e3.jpg
Oil change and new filter tomorrow and hopefully the calipers painted, fitted up and blead.
Looks really really good with those painted inner arches mate! :)
Top work! The cars a credit to you
As stunning as ever, loving that last pic.
Its just this that lets it down ;)
lol
Adam, 1.2's are the future!
lol I know fella.Quote:
Think I'm gonna start building a nicely spec'd 1.3 on twin 40's over the summer (when I've got some money coming in) and get a CR F13 box for it. Then come the end of the summer I aim to rebuild the car and do the engine conversion then. Just leaving the engine as it is for now for cheap insurance and just because I don't want to do anything else with the car now except drive it!
it is the bollocks this car. Awesome.
Looks really good mate, I wouldn't of been able to stop myself making a sport replica out of it, is it missing wheel bolts in the side shot?
Cheers dude!Quote:
Originally Posted by peester
Aye, it's still tempting to do a Sport rep but I like the fact that it's different to anything else. It'll pretty much be a sport bar the decals once the engine has be fettled!Quote:
Originally Posted by Graeme Dixon
Yer it's missing a couple of bolts form each wheel, just beacuse I'm only rolling it in and out of the garage atm and because I've had the wheels off alot lately.
nova coming along nicely chum, nice simple mods, nothing to over the top..
good work..:thumb::thumb::thumb::thumb::thumb::thumb:
Just wonderingis it a4or 5 speed,Matt?
