Good 1st days work! Looks a great shell.
Roll on tomorrow!
Roll on tomorrow!
Excellent work, keep it up :)
well very little progress today as i was on call :wtf: and got called away so only spent a very short time on it quite frustrating :mad: :tard:
new injection tank ready to go in
http://img.photobucket.com/albums/v2...a/DSC00391.jpg
removed the old brakets taht are not needed
http://img.photobucket.com/albums/v2...a/DSC00390.jpg
http://img.photobucket.com/albums/v2...a/DSC00389.jpg
the slight surface rust cleaned off afterwards
next marked out the cut out for the alternator
http://img.photobucket.com/albums/v2...a/DSC00392.jpg
then made a start
http://img.photobucket.com/albums/v2...a/DSC00396.jpg
oh and modified my regal enlarged top hat
http://img.photobucket.com/albums/v2...a/DSC00394.jpg
comparision with a standard top hat
http://img.photobucket.com/albums/v2...a/DSC00393.jpg
had a few problems with the chris astley conversion mounts and the solid mounts the bolts supplied with the solid mount kit would not fit the conversion mount they are to large a diametre so have to enlarge the holes npics on my phone bit my phone is playing up and wont let me get pictures off it
welding WILL be done tomorrow aswell as the strengthening kit fitted
well a bit of progress today my brother welded the strengthening kit on and stich welded the engine bay and we trail fitted the engine and f28 and he then welded the mount on the chassis leg
rear beam support brackets
http://img.photobucket.com/albums/v2...a/DSC00397.jpg
1 of the 3 lower arm strengthening plates
http://img.photobucket.com/albums/v2...a/DSC00398.jpg
o/s/f crossmember strengthening plate starting to be welded in
http://img.photobucket.com/albums/v2...a/DSC00400.jpg
n/s/f
http://img.photobucket.com/albums/v2...a/DSC00399.jpg
tie bar support plates
o/s/f and a bit of stitch welding
http://img.photobucket.com/albums/v2...a/DSC00402.jpg
n/s/f
http://img.photobucket.com/albums/v2...a/DSC00403.jpg
strut top plates
http://img.photobucket.com/albums/v2...a/DSC00412.jpg
bay in the middle of the stitch welding
http://img.photobucket.com/albums/v2...a/DSC00401.jpg
cut out chassis leg ready to box it in
http://img.photobucket.com/albums/v2...a/DSC00413.jpg
looking good and a good write up/report/pictures etc
Coming along nicely.
we then grabbed a spare c20let and f28 to trail fit and see were the new f28 mount had to go
so one engine and box
http://img.photobucket.com/albums/v2...a/DSC00404.jpg
under the car
http://img.photobucket.com/albums/v2...a/DSC00406.jpg
slam panel removed for easy access to turbo etc
http://img.photobucket.com/albums/v2...a/DSC00407.jpg
mount in place
http://img.photobucket.com/albums/v2...a/DSC00408.jpg
bolted up and then tacked in place
http://img.photobucket.com/albums/v2...a/DSC00409.jpg
solid mount beinge removed
http://img.photobucket.com/albums/v2...a/DSC00410.jpg
engine removed and welded up
http://img.photobucket.com/albums/v2...a/DSC00411.jpg
so the plan for tomorrow is my brother has 2 more plates left to weld in, do alternator recess finish off welding all the plates in fully (very little to do ) then the car can go to the body shop and the engine bay painted
but at least the engine will physically bolt in the engine bay now which is nice!
spot on mate :thumb:
cheers
Nice work.
You not welding the bulkhead seams?
yeah they are being done tomorrow car carpet and interior are still in it thats why we couldnt weld the last of the pates in due to the carpet etc will be removed tomorrow and all around bulkhead will be welded 5 min job compared to trial fitting enigne etc and figuring out where the plates go lol
You lot don't hang about!
Good job,nice welds too..
lol yeah my mate Mike found out the hard way on the bulk seams, i told him to make sure it was all cleared of carpet/deadening etc so when his mate welded it up, woopsy some one didn't,and a fire broke out,costing his mate a new driver window (punched it through to put the fire out) new dash-wiring loom-toad alarm, not good eh!
Keep up the good work.
Keep it up mate, looking good! :)
cheers no point hanging around is there!
did a little bit more mincing on the nova today
started by finishing off the alternator recess
went from this
then used the bit that we had cut out
http://img.photobucket.com/albums/v2...a/DSC00414.jpg
tacked in so recess is formed
http://img.photobucket.com/albums/v2...a/DSC00415.jpg
then weld it
http://img.photobucket.com/albums/v2...a/DSC00416.jpg
then clean things up as plate was to large and protruded out form chassis leg nothing a bit of sanding couldnt fix
http://img.photobucket.com/albums/v2...a/DSC00417.jpg
bulkhead seams
http://img.photobucket.com/albums/v2...a/DSC00420.jpg
http://img.photobucket.com/albums/v2...a/DSC00419.jpg
on its wheels welds primed and engine bay being scotched and things masked off ready for paint shop tomorrow
http://img.photobucket.com/albums/v2...a/DSC00421.jpg
Some quick progress there.. going to be a cracking car this :)
i think what will make or break the cari s the quality of the plug cover ;)
I only hope it lives up to the rest of this quality build! :)Quote:
Originally Posted by corsakid
Make sure and remove the servo and the plate on the oposite side, along with the steering rack etc to make a proper job of it.
servo is gone mate , rack will be left in place until it gets to the bodyshop we are pushing it round 20-30m from current unit, new engine and box on its way from bony scotland they should be here tomorrow or saturday
Originally Posted by Nick J
it shore will mate, as for quality build i wouldnt quite go that far i am trying my best put it that way, i am by no means an expert and wont pretend to be, but hopefully the car at the end will turn out OK :)
well bit of a slow day today
we seam sealered the the welded seams etc to day at 9.am this moring was supposed to go roud to be painted this after noon but i think due to the fact it was so cold the seam sealer was only just starting to set at 5pm this evening so will have to be tommorw or monday for paint now :cry:
everything was masked off whilst rubbing down and priming the rack is loose and will be removed for paining when at body shop
http://img.photobucket.com/albums/v2...a/DSC00424.jpg
http://img.photobucket.com/albums/v2...a/DSC00422.jpg
http://img.photobucket.com/albums/v2...a/DSC00423.jpg
but whilst the seam sealer was setting we painted all four arches and the whole underside of the car 15 year protection better then your usual underseal!
battery died on phone so the pics are during the painting process the struts were removed after these pics to get in behind and up inside the turrets :) suspension is just temporary untill my coilovers arrive
http://img.photobucket.com/albums/v2...a/DSC00429.jpg
http://img.photobucket.com/albums/v2...DSC00427-1.jpg
http://img.photobucket.com/albums/v2...a/DSC00430.jpg
will get better pics tomorrow before the shock absorbers etc are refitted and when its dry a second coat will be added added aswell
Looking good all underneath painted mate - Did it take long to do ?
Your thread confuses me, whose typing? Kris or Gary? lol
Either way - looking stonking, very neat application of seam sealer :thumb:
Did you weld the seams insides the arches? Looking good.
:thumb:yeah all painted underneath took a few hours will be doing another coat todayQuote:
its me kristan than usually posts up the progress (its pretty much a joint effort maybe more so on my part as my brother is relatively new to all this and is an electrician by trade and i am a mechanic etc but it is his car and his ideas for the build i just help it happen sooner rather than later lol) i user my user as garys (my twin brothers) internet isnt working at present thats the reason for thw 2 wip threads on the same user sorry for the confusion glad you like though olly :thumb:
yeah benn the seams have all be welded and the full strengthening plates added, didnt feel the need to seam sealer inside the wheel arches painting is more than enough in my opinion:thumb:
Nice build so far. One concern, is the F28 mount welded to the chassis plate or the chassis leg? Wouldn't want that to tear off with the plate!
its half welded on the the leg itself and half on to the plate!
i am confident the plate will not come off it has been welded heavily, considering the std mount had 4 spot welds i dont think it will come off in a hurry
Good work.
The hammerite smooth blue is a good match.
yeah once it has dried a little it darkens down and is almost a perfect match for the exterior :) very happy with it once it has gone of i can get cracking mounting the pump and new brake and fuel lines :)
cracking build there matey - talk about a perfect base to work from.
Looking forward to seeing the final thing...
thank you mate it should be about in 2009:)Quote:
Originally Posted by ade
well had a few things delivered to day the engine bay still isnt painted :mad: which is holding this up massively but any ways a few things turned up today for the nova my turbo pre filter
after having a few turbo failures in the past and all have been blamed on oil contamination imho (absolute rubbish) decided to by a prefilter
http://img.photobucket.com/albums/v2...a/DSC00434.jpg
http://img.photobucket.com/albums/v2...a/DSC00433.jpg
brand new cv joints inner and outer for the shafts the one below is of the equal length shaft with out the calibra part of the setup its at my garage at home so built up what i had
http://img.photobucket.com/albums/v2...a/DSC00435.jpg
http://img.photobucket.com/albums/v2...a/DSC00436.jpg
new wheels bearings all round were purchased aswell to day
and guess what turned up at 3 pm this after noon my new steel bottom end engine with arp head studs and every arp bolt avalkible for the bottom end installed done 400miles so is still in the running in process
and my fully rebuilt 2k ago quaife diff'd f28 with f20 speedo drive and 2wd drive converted :D
http://img.photobucket.com/albums/v2...a/DSC00437.jpg
http://img.photobucket.com/albums/v2...a/DSC00440.jpg
http://img.photobucket.com/albums/v2...a/DSC00439.jpg
fitted mount as it has already been pre tapped etc :D
http://img.photobucket.com/albums/v2...a/DSC00441.jpg
waiting on my lightened flywheel wheel and paddle clutch to arrive so it can be bolted in but no rush as am still waiting on paint shop
Cracking on now, cant wait to see the bay done, and engine in!
me neither will be worth the wait
Good work :)
thanks alot
might be worth welding in a brace across that rear mount mate as they tend to flex, especially the power you'll be running. The GTE/GSi had them as standard.
http://img.photobucket.com/albums/v3...02-03-2008.jpg
Good work so far dude.
