has any one got any more pictures of these fitted as im serisoly(sp) thinking about fitting some
Fitting some Diesel clocks to my petrol car at the moment... Will they work ok?
Also, what a **** of a job! my hands are shreaded. I cant seem to get them to go back enough either which is annoying.
did you trim the heater ducting ?
yeh, quite a bit aswell. ive also had to cut the bottom tabs off the cav dials.
is it catching on the speedo cable?
maybe try re ruiting it
wiring in the way?
Anyway i can pull the speedo cable from the engine bay so its not as slack?
Could be the wires aswell, ran out of light today!
And the rev counter under reads by around 1000 rpm is this because its a diesel clock? Could i get a new face for it from a petrol and put it on, or is it to do with the way its wired?
not so sure on re wiring the clocks but personaly i would have got a full set from a petrol model
iirc its because they're diesel clocks, would be better off selling them and getting petrol clocks
I had to make a few small cuts into the metal brackets for the steering column
i have just done this ant the fuel gage reads diffent to the nova gages could it be te sender from the tank or should i fit the calibra sender
