http://sadpanda.us/images/1724029-MUCRVUL.jpg
lol As said, i didn't like a single before, but now i kinda do. But i want a good screen clearing wipe. And with a single so far i've not got that. What do you use?
One of those old storm off the shelf ones, but seeing as you can weld, anything's possible to adapt. Wipe's fine, guess it comes down to correct straight arm & blade.
Can you still buy them? I do like the single look if its set right over.. But at the mo i thing i'll be happy with good working ones.
Prices haven't changed much from somewhere like here: http://www.autotintdesign.com/singlewipers.html
But all you're paying for is a bit of adjustment on a piece of bent steel tube with the same factory ends; isn't what you're running chopped about anyway because of where the motor is? You could adapt that.
Or if you moving the motor anyway... :) (from here: clikky)
http://i248.photobucket.com/albums/g...alepics028.jpg
its better use a Citroën single wiper or modify the vauxhall?
The Citroen one means it all nice and compact. Good if you have no fire wall.
