Yep, or may be something sooner which will be revealed soon :)
Nice progress Lee. Hope everything comes together for you.
:D good laaaaaad ;)Quote:
Originally Posted by Lee
Nice one mate, i see it's gone together quite nicely..
And i like the sticker on the wing! :D
"Its alive". Well nearly. good work bud.
Any progress??
Nope, mainly due to work and money, but with a bit of luck i can crack on in the next few weeks.
wow i missed this lee, bet you can't wait to get it out on track (with 4 fully functioning rods)
Well its been a while since Ive had a tinker, so seeing as i have a few days off from the grind, i thought id best prep the car for Combe in a week and a half :)
First job was to work out why me wipers stopped working. I unbolted the wiper mechanism from the SR and plugged it into the track car, and the moror worked fine, so plan two was switch on the wipers, and tw@t the motor with a spanner lol Low and behold, it worked, so out came the WD40 and i left them running for a while. Work fine now, but it may need a new motor if it happens again.
Second job was to fix the fuel leak that occured just as i put it away from the RR day. Turned out the jubilee clip holding the return pipe onto the line had broken. Nice easy fix :)
Then some new goodies. Me new steering wheel and 4 point harnesses on the drivers seat :)
http://img.photobucket.com/albums/v2...0042008021.jpg
http://img.photobucket.com/albums/v2...0042008024.jpg
Then i bogged off down the tyre shop to fit my part worn Dunlops i got through the other day.
http://img.photobucket.com/albums/v2...0042008023.jpg
They were cheap as chips, have plenty of life left in them BUT.. theyre 195/55/15's, so i was risking it for a biscuit.
As per my luck recently, they just touch the springs on the inside on all 4 wheels, so im going to need some 1mm spacers. Hopefully that wont give me issues on the outside, as im fecking close to the arch as it is!
Other than that, it appears im ready earlier than I have ever been for combe! W00t :)
LOL good going, tyres look interesting mate, so if your all done on yours do you Fancie popping over to Dar's and finishing mine for me and then getting through the mot? lol lol
