http://img.photobucket.com/albums/v2...v/DSC00400.jpg
http://img.photobucket.com/albums/v2...v/DSC00399.jpg
Strut brace all fitted up!
Just been re-locating the oil pressure sensor, what a complete ****!, its done but got no room for the standard sender now, ****!
Mate i can make you up a nice fitting so you can you use both senders. It consists of some nice swaglock fittings and one fitting from the hose place in millbrook. Basically ive moved the after market sender further up the block out of the way giving you plenty of room for the standard sender.
Job done.
That would be spot on mate!, will just go by the spa read-out for now as that should be cock on!
Bay looks the bollox :cool:
Cheers Ad, Twag all sorted now mate, forgot i had that old xe bottom end from Gavs calibra, it had the smaller switch fitted that must only read low pressure, that went in a treat!
Re fitted the boost pipe and the plug leads, just waiting on a phone call to pick up the bodywork bits and bobs!
awesome looking car excellent engine bay, one of my fav nova's right now!
Got the body work stuff! looks good, didnt have enough time to finish wet flatting the top edges of the tailgate, but i had no time to wait so will have to get a mate to finish it after billing!, I also forgot to get a plate welded where the old push lock part goes... fail lol
*cough*pri*k*cough*
Be carefull flatting off edges.
Any the fudge nudger has broken it gen!
