Car looks good dude, hows the saab anti roll bar ive just ordered one of these also?
Well, this car is still being worked on and improved.
The engine has gradually been burning more and more oil. The bullet was my mate saying actual pieces of oil were hitting his windscreen behind me. Suspicion was stem seals so off comes the head:
http://iainel.co.uk/images/forums/NovaWIP2b/570.JPG
Definite signs of oil burning:
http://iainel.co.uk/images/forums/NovaWIP2b/571.JPG
16 Elring stem seals fitted, and a bit of valve lapping while there:
http://iainel.co.uk/images/forums/NovaWIP2b/572.JPG
ARP head studs so I felt like there was a point to yet another engine strip down:
http://iainel.co.uk/images/forums/NovaWIP2b/573.JPG
Fitting them. SBD instructions say you need 5mm spacers on a late head which is 74mm deep. With the provided washer it's pretty close to the end of the threads, so I fitted the ARP washer, OE washer and ARP nut to ensure I was in the middle of the thread:
http://iainel.co.uk/images/forums/NovaWIP2b/574.JPG
Done, never to be seen again:
http://iainel.co.uk/images/forums/NovaWIP2b/575.JPG
Test drive seems pretty good, it definitely smells less so fingers crossed.
Bit of preventitive maintenance for once, Wilwood caliper rebuild.
Technique was get a piece of wood and pressurise the caliper with an airline to get the pistons out most of the way:
http://iainel.co.uk/images/forums/NovaWIP2b/576.JPG
Seals pretty good, pistons very bad. Caught it in time.
http://iainel.co.uk/images/forums/NovaWIP2b/577.JPG
New pistons from RallyDesign are a way nicer design - cast then machined OD. Look way better made than the old ones:
http://iainel.co.uk/images/forums/NovaWIP2b/578.JPG
8 new seals and pistons fitted, bolted back on and bled with Motul 660 fluid.
Also rocking a single carbon kevlar Cobeau now:
http://iainel.co.uk/images/forums/NovaWIP2b/579.JPG
Car weighs in at 820kg with over 20L of fuel.
Trackdays are running again so booked onto Mallory at August.
One.
Nice update. Hopefully the engine can stay together now until the end of the season!
Loving a bit of carbon/kevlar :cool: Was gutted to have to sell the corb rev ones I had, but just don't fit with the red tunnel:(
I'm playing with this bumper idea, I'm 50/50 whether to carry on or scrap it.
Proper ropey, basically scrap GSi bumper
http://iainel.co.uk/images/forums/NovaWIP2b/580.JPG
The edges were cut off for wheel clearance, which just looked terrible once fitted:
http://iainel.co.uk/images/forums/NovaWIP2b/581.JPG
I was torn between a few ideas, but the top is basically the same between povo and GSi, so I thought I'd try making a GSi "Alpina style bolt on valance" from it:
http://iainel.co.uk/images/forums/NovaWIP2b/582.JPG
This is it bolted to a spare povo mk2 bumper which is pretty much cut away to just be the upper part and sides:
http://iainel.co.uk/images/forums/NovaWIP2b/583.JPG
Quite happy with the fit into the existing swage line:
http://iainel.co.uk/images/forums/NovaWIP2b/584.JPG
Not 100% sure on the lip it's left here, but I guess that was inevitable:
http://iainel.co.uk/images/forums/NovaWIP2b/585.JPG
Hmmmm.
