Engine started up and running with no issues
https://youtu.be/CXyFStZilr0
Big check off the list!
Inside is all finished off nicely https://uploads.tapatalk-cdn.com/202...64b1f68019.jpg
https://uploads.tapatalk-cdn.com/202...d0af7bfd55.jpg
https://uploads.tapatalk-cdn.com/202...a4a7fdd0ac.jpg
https://uploads.tapatalk-cdn.com/202...763576e1a7.jpg
https://uploads.tapatalk-cdn.com/202...0234b25ef4.jpg
Such a cool build [emoji41]
Compomotive TH Wheels all stickered up
https://uploads.tapatalk-cdn.com/202...af5d0e8ba9.jpg
Engine breather system nearly done, just waiting on a breather filter.
https://uploads.tapatalk-cdn.com/202...03e1cf6dc5.jpg
Gold reflective heat tape put on the exhaust tunnel
https://uploads.tapatalk-cdn.com/202...9ddcc88300.jpg
New F20 machined hubs with SKF bearings & new flanges
https://uploads.tapatalk-cdn.com/202...606dd6b1e4.jpg
Few more jobs and it should be on the road
The progress on this is crazy, you're certainly not hanging about lol
Just waiting on some Steel Tube & Round bar for my Quaife gear linkage, then the cars going up to Angus Lawrie Motorsport to get the linkage all done and a few other jobs.
Also booked in for a Exhaust at Tony Law late June.https://uploads.tapatalk-cdn.com/202...72c3791126.jpg
Bonnet finished it off nicely
https://uploads.tapatalk-cdn.com/202...9f1fc37209.jpg
https://uploads.tapatalk-cdn.com/202...02c4010930.jpg
https://uploads.tapatalk-cdn.com/202...050b36b823.jpg
https://uploads.tapatalk-cdn.com/202...a140cee078.jpg
Long wait till the end of the month for gearlinkage & exhaust to be done. Nothing else to finish off [emoji1305]https://uploads.tapatalk-cdn.com/202...90c1ab801c.jpg
:d:d Looks Absolutely Brilliant!
Car goes away tomorrow for Gearlinkage & a few other jobs then off for a exhaust system.
So hopefully when it’s back in 2 weeks it will be on the road and I can start running the engine inhttps://uploads.tapatalk-cdn.com/202...2fc85e59b8.jpg
First time it’s seen some sun light, the inside looks totally different with natural sun light on. Really impressed with it https://uploads.tapatalk-cdn.com/202...06f76d1761.jpg
Good update from this past week. Car went up to Angus Lawrie Motorsport for a few jobs and collected it today.
Quaife Gear linkage
Kevlar Sill Guards
Full suspension geometry
Mudflaps
Few photos to follow
https://uploads.tapatalk-cdn.com/202...153b5388ae.jpg
https://uploads.tapatalk-cdn.com/202...5e3648ae86.jpg
https://uploads.tapatalk-cdn.com/202...3a9112da7e.jpg
https://uploads.tapatalk-cdn.com/202...597bf588b9.jpg
https://uploads.tapatalk-cdn.com/202...5b98bfa131.jpg
https://uploads.tapatalk-cdn.com/202...3483b5395c.jpg
https://uploads.tapatalk-cdn.com/202...ed53001de6.jpg
https://uploads.tapatalk-cdn.com/202...7c9d1eb03a.jpg
https://uploads.tapatalk-cdn.com/202...e6c9d96e1d.jpg
Looks a totally different car now with the sill guards & mudflaps. Gear linkage is so precise and the throw between gears in minimal, whole car will take some time to get used to.
Take the car down to Tony Law exhausts on Tuesday for a custom system then ready for a MOT next Saturday.
That is looking fabulous, an absolute credit to your efforts.
Looks a serious weapon. Awesome build!
Like that gear linkage, looks solid.
Mintex F6R pads have arrived from Questmead for the 256mm 16V calipers. Group A shafts from Protec should arrive sometime this week aswell.https://uploads.tapatalk-cdn.com/202...0cb3c6d28e.jpg
Tony law Exhaust all finished, all bolted to the car and tucked up out of the way. Skidded around the tank & axle area aswell https://uploads.tapatalk-cdn.com/202...a8de96c440.jpg
https://uploads.tapatalk-cdn.com/202...c394b19001.jpg
Exhaust looks quality :thumb:... and that fuel tank looks like it's carbon fibre :eek:
I don't normally like to ask, but what did the exhaust cost you?
Ahh right... still looks sweet though!
Shame you have to take it off the road so quickly, but if you've had the gearbox off before, it won't take you long to have it put right.
Car is looking good. :thumb:
Nick
My fault for not checking the clutch when I put it in, too worn which was causing it to slip. Got it all out in a hour .https://uploads.tapatalk-cdn.com/202...1cebc7e12b.jpg
https://uploads.tapatalk-cdn.com/202...32c3347c2e.jpg
https://uploads.tapatalk-cdn.com/202...c94718d48e.jpg
Not much I can do as waiting on a new helix clutch being made which I should get in a couple of weeks. Swapped over the release bearing cone that was used on the AP clutch for a standard one with a new bearing
https://uploads.tapatalk-cdn.com/202...8f6f0c7318.jpg
https://uploads.tapatalk-cdn.com/202...e80e387df2.jpg
New 184mm helix race clutch has landed and got it put onto the engine ready for the box to go back inhttps://uploads.tapatalk-cdn.com/202...8e9b1aca27.jpg
https://uploads.tapatalk-cdn.com/202...838916b688.jpg
https://uploads.tapatalk-cdn.com/202...3b084375f7.jpg
Come on mate, you're slipping here!!! Mine was back in and the car running 4 hours after it arrived in the post!! Hahaha
On a serious note, I hate clutch and gearbox related issues, it's such a pain to do anything about, they're on my list of things I hate, up there with genital warts and syphilis.
New clutch looks a good bit of kit, is that a TTV flywheel??
I know hahahha, wish I had the time to put the gearbox in but that’s gonna be my task tomorrow. Yeah well I thought it was gonna be abit of a pain in the arse to get the box out when it was just on axle stands,but it probably only took 30-45 mins. Don’t miss lying on the floor with a F20 on your stomach!!
Well impressed with the clutch, just a recommendation from Bill Falconer when he made the engine for me and it allows me to run a standard release bearing instead of a homemade setup like on the AP.
Flywheel is just from SBD Motorsport, 2.78kg and it’s just a 7.25”/184mm size.
Fly wheel looks a lot like my TTV. Lovely bit of kit, well mine was lovely until a friction plate paddle ate most of it!!!
I did cheat when it came to putting mine back in as I had the use of Ben's ramp, which makes things easier.
Using off the shelf parts is better than having to fabricate one offs, especially for things like clutches as it's such a pain to get to!!
When is your next event??
Yeah I’d never heard of TTV until you said so I went to have a look on the internet and they look exactly the same! I seen the damage from the friction plate on your thread, lucky not to do any more damage. Never seen a plate fracture like that before.
I had a go at trying to get the box in today but definitely need a 2nd pair of hands just to get the box onto my stomach and then a hand with lifting it up. Yeah a ramp is so much easier and transmission jack can save half the hassle.
Yeah your right and I didn’t wanna go away from what Bill had recommended as I think he’s had a few issues with AP clutches on his engines before.
I’m unsure on that, entered into a championship this year but with the virus near enough all the events have been affected. So I think it might be a few local single venue rally’s or rally time trials which I have seen a few advertised.
Yeah the TTV is good gear.
My clutch was FUBAR!! Lucky it didn't destroy the box and block!!
Im hoping trackdays don't get cancelled again as I've a few booked and JSS at Cadwell in October.
Get some videos up of you rallying, be good to see some action
My thoughts exactly, very lucky it didn’t take the clutch cover with it aswell!
I thought about doing a track day at Cadwell, it’s probably the only circuit that would suit the car with how low geared mine is especially around the mountain section onwards. Maybe not at the back end of the circuit, but it has crossed my mind to do something there as 2 rounds of the Motorsport News Circuit Rally championship are held at cadwell.
Yeah I deffo will, thinking of booking a local karting track for its first proper go out so shall get some in car.
Well if you're thinking of a trackday at Cadwell then keep me updated as I'll get booked on too
Car might see the road very shortly after having continuous clutch release bearing issues. Should have it all sorted now I have got a boss made up for the bearing by someone from work. Hope to take the car out for a good few miles to check everything is working how it should and then get it tucked away for winter.
https://uploads.tapatalk-cdn.com/202...2b8c678b93.jpg
https://uploads.tapatalk-cdn.com/202...dd2b908548.jpg
https://uploads.tapatalk-cdn.com/202...6481179ff8.jpg
Chunky spacer! I can't imagine trying to do events without road shake downs beforehand. REIS are good for competition car insurance.
