Is it just me or does it look a bit far forward as well, thought it was meant to be level with the B pillars.
That's what I thought mate! Mine's level with the B pillars
Personally can't see the point in non approved roll cages.
Who the hell sold you that roll cage? its a compelte pile of **** go and weigh it in for gods sake
lmao...... true though!Quote:
Originally Posted by NickWalliams
sorry bad day the other day take ma jerks back,cage jus looked normal to me,doesn't weight alot at all. so what bout omp ones ive seen with adjustment right in middle? and cage is only placed in car so its out of the way so thats y its forward.
Never seen one, but the fact is a steel weld will be as strong, if not more than the metal itself. That is NOT the case with aluminium though, and the fact that if you rolled over it would bend significantly, or as mentioned, possibly snap at the weld and spear you or your mrs.Quote:
Originally Posted by c'2.0lrt
End of the day, its your barnet, but IMO if you want a shiney cage, get a steel one chromed.
should i ask mps bout this?
Wouldnt be much point as it'll be advertised as for off road and show use only.
You shoud say something to them as Ive never seen a roll cage welded like that before, maybe it was a reject or got damaged or something? or they had run out of decent lengths of tube.Quote:
The weld is the week point just like it is on a mountain bike frame even when made of steel. Hence why bike frames have butted tube so it is thicker at the welds.
