so temp gauge you deffo need a mk4 astra ecu installed? guessing they have a car ecu separate from engine then?
surely there is a way of making the fuel gauge work ?
cant you somehow use the vx/lotus sender?
I guess the fuel gauge issue depends on what you can install in the fuel tank on a Nova....
Another missing piece to the puzzle, Dom on MIG no longer makes the pulse convertors so not sure if the speedo would be accurate with one of those.
how come he's not doing the convertors anymore?
Nov 21 2014
Originally Posted by Dom
Game over then
from the parts manual, the Lotus Stack seems to use an ABS reluctor ring on the driveshaft as a speedo pick up. All you would have to do is find out how many teeth are on it and make your own driveshaft trigger. Probably find a corsa ABS drive shaft has the amount of teeth as the rover/toyota if youre lucky. Then use an ABS hub and pick up and it should be easy to get it to work acurately. I cant see any info on the VX gauges to see how they work.
the temp sensor thing seems odd, why not just use the lotus/VX/Rover/toyota sender with the Stack? i very much doubt it runs through the ECU first as they usually use separate sensors.
I'll dig through the wiring diagrams I have for the Elise and see what's what.
the mk4 Astra, like many cars of its era (and the beginning of the modern good era) have an engine controller (what most call an ecu) and then a body control module which is also an ecu since it means electronic control unit lol
manual: http://www.sandsmuseum.com/cars/elis...ceManual11.pdfQuote:
Originally Posted by http://www.vx220.org.uk/forums/topic/111831-speedster-elise-cluster/
fyi
I've been looking at making ABS sensor -> dash convertor for the VX folks as many want to do away with the ABS completely but its at the bottom of my development pile lol
