nice wheels mate you picked a colour for it yet nd have you got any videos of it racing
Oh my those wheels are sexy :wisewood:
I've now caught up with him, and the Nova is booked in for paint stripping in a couple of weeks time. John reckons that the powdercoat will actually be lighter than wet spraying paint, but he is also a chemist by profession, so he's going to do the calculations to be 100% sure. He also says powdercoat is perfect for finishing the underside, wheel arches and engine bay, so I may as well get all those done whilst it's with them.
That will just leave an outer top coat to apply once all the carbon fibre/fibreglass panels are fitted into place.
What I still haven't decided on is the colour!
So, with a deadline to work to, I've started getting all the bits removed from it, and I've got cracking with all the structural metalwork which needs doing before it can be primed.
Photos to follow soon!
Carbon fibre front end removed (not very tricky!);
http://i285.photobucket.com/albums/l...ort/002-57.jpg
http://i285.photobucket.com/albums/l...ort/003-59.jpg
Intercooler and radiator removed, along with the front slam panel;
http://i285.photobucket.com/albums/l...ort/005-40.jpg
Bit of messing about with a slightly smaller width radiator, which would allow me to get a more direct airflow into the turbocharger;
http://i285.photobucket.com/albums/l...ort/004-48.jpg
http://i285.photobucket.com/albums/l...ort/011-27.jpg
http://i285.photobucket.com/albums/l...ort/006-41.jpg
Unfortunately the alternative radiator is slightly taller than the old one, and there's not enough room under the slam panel for it, with the intercooler on top as well. The only way I'm going to be able to accommodate it will be to slant the radiator forward to get some clearance.
I've chopped the rest of the front inner wings out to save a bit more weight (about 1.5kg);
http://i285.photobucket.com/albums/l...ort/010-31.jpg
http://i285.photobucket.com/albums/l...ort/009-32.jpg
The gaps will be filled in with carbon fibre sheet eventually.
I'm also carrying out major metalwork at the back end, removing all the metal I can get away with in accordance with the Regulations;
http://i285.photobucket.com/albums/l...ort/012-28.jpg
http://i285.photobucket.com/albums/l...ort/013-21.jpg
http://i285.photobucket.com/albums/l...ort/014-24.jpg
http://i285.photobucket.com/albums/l...ort/017-33.jpg
http://i285.photobucket.com/albums/l...ort/018-29.jpg
The pile of rear metalwork so far (nearly 4kg);
http://i285.photobucket.com/albums/l...ort/019-25.jpg
I shall take expert advice before I do it, but I plan to also remove the rearmost sections of chassis rail behind the mountings for the anti roll bar, along with the outer sections of the wheel arches;
http://i285.photobucket.com/albums/l...ort/015-26.jpg
http://i285.photobucket.com/albums/l...ort/016-32.jpg
I've also acquired a rather nice carbon fibre brake pedal, which previously did service in a 1992 Formula 1 Arrows Footwork car;
http://i285.photobucket.com/albums/l...ort/002-59.jpg
http://i285.photobucket.com/albums/l...ort/001-24.jpg
I have serious doubts about whether it can be made to fit my pedal box, but it looks nice.........
And my existing alloy oil catch tank is too heavy, so I'm going to make my own out of carbon fibre, using some of this tubing I got hold of;
http://i285.photobucket.com/albums/l...ort/021-19.jpg
http://i285.photobucket.com/albums/l...ort/020-21.jpg
Getting rather happy with the grinder there Colin lol
As for the rear sections since you've cut out all they attach to you'll lose nothing by trimming them down, in fact trimming them down and then capping them off may well be stiffer if anything, at the moment though they're just flapping in free air so not doing anything at all. I would leave your wheelarches as is as they're actually probably the strongest thing on a nova, and your ARB attaches to them.
Edit: although anything behind the ARB or the outer part of the arches or actually 'inner arch' as you'd call them if doing bodywork like an arch repair if that makes sense?... could go, as they're only .5mm stuff and not really structural.
Not sure if its already been discused in the previous 152 pages - but a weight saving trick the Nova rallycross challenge cars used to do is trim down all the door/window apperutures where the rubber seals sit - you could probably lose about 6/7 mm round each door/window etc before you refit the rubbers (You've probably done away with the rubbers already ;) )
It's not something the scrutineers used to pick up on !! - and every bit counts
Its only bending the rules slightly :) - Is there a specific rule that you would be breaking ? Your only bringing the shell to within Vauxhalls 5mm tollerance of panel fit of the 80's -LOL
The exhaust system is on the 'in need of attention' list when it comes to weight saving;
http://i285.photobucket.com/albums/l...ort/009-33.jpg
The complete side-exit system from the turbo back weighs in at nearly 5.5kg.
I've been in consultation with a local exhaust specialist that does a lot of work with race bikes, and we've decided to make a larger bore system out of aluminium tube.
The heat close to the turbo will prevent aluminium being used at that end, but it won't be a problem further back, and will offer a useful saving in weight, and maybe some extra power/torque from the larger bore.
We looked at titanium and Inconel, but the costs of materials is high, and the fabrication costs are even worse.
Aluminium is lighter still, easy to work with and relatively cheap.
On a race car used over short distances like mine, it would appear to be the ideal solution.
Would ally tube survive the heat off the turbo? The airflow on a bike is way different to under a car floor
I've been doing plenty of research on the subject, and I'm confident that it can survive in the short duration bursts it will see.
This link has loads of information (and some of the nicest welding I've ever seen);
http://honda-tech.com/showthread.php...minium+exhaust
Seems aluminum (as they call it) is pretty common in the USA for exhaust systems.
it used to be called aluminum here too, but some scientists fell out & they changed it......
I just love this thread.
The dedication is supurb and its great when i see the Kg's falling off the car.
What realistically do you think you can get the car down to weight wise?
I often laugh when i see people go to these measures to loose weight off there car then i see them on the drag strip and they are 20 stone!
Surly a huge investment would be made in Driver weight also - Its free also :)
I cant remeber your size though so you cant be a big person or it would have stuck in my mind :)
Great work Colin
Love the chopping & the workshop looks good too :)
re the acid dip argument.... if you did strip & acid dip it, then clean it up properly, followed by a really thin coat of paint, it would save you a fair few kg, but you obviously would need to keep it in the dry to stop it rusting..
i read a story about the skoda rally team.. they were so short of funds, that they had to get really clever, so the rally shells would be put thru the acid baths on the production line time & time again to get the metal thinner to get the weight down.
Not much to report as I've barely been at home in the last couple of weeks, but a small update;
Carbon fibre seat mounts have arrived, specially made for me by my friend Simon at Reverie;
http://i285.photobucket.com/albums/l...ort/006-44.jpg
And some more custom bits knocked up by a friend in his lunch hour;
http://i285.photobucket.com/albums/l...ort/013-22.jpg
And the start of my experimentations with making a carbon fibre gear lever, to replace the rather heavy duty billet alloy one that's been in there previously;
http://i285.photobucket.com/albums/l...ort/012-29.jpg
every kilo helps, is that a solid carbon rod or is it a tube?
im guessing that weighs bugger all then
My friend still cant believe that steering wheel never mind the car!
keep up the good work.
Angus
Where's the carbon rod from Colin - looking for some for my project
I've been using www.carbonology.com excellent service and good quality
how much wet running do you do colin? im gussing not alot, if that is the case cant you ditch the wiper set up?
Is that big alloy plate under the pedals as thick/heavy as it looks? If so, ripe for a cored carbon sheet with inserts in it.
Not sure id be so keen on a carbon column if Im honest. but you could certainly swap out the heavy rods for some larger diameter CDS tube?
Looking really good though! An inspiration on weight saving!
Colin just going back to paint or powder coat would a Vinyl rap be lighter ?.
Do like those seat mounts!
Sorely tempted to nick that idea & make some at work over the weekend, more for sheer looks TBH lol lol
