All that weight saving has given me a ROD on lollollol
Ah ok cool, what does h-section mean then?
the cross section through the rods is an H shape, it gives the rods a greater moment of inertia for a given mass to reduce the deflection without increasing weight. Or in this case to reduce the weight and I'm sure increase strength/stiffness!Quote:
Works the same way an RSJ does.
I take it needs 400cc less to go all the way lolQuote:
Nice little bit of weight saving, good to see your still tinkering with the car!
And when its back on the road is it any chance i can pay you to make a copy of your rear diffuser. pretty please :):D
Wha?:tard:Quote:
so its H shaped for strench, right i get that bit.
lol lol lol
If you have a plastic ruler its easy to bend when it's flat, but impossible when it is rotated 90deg along its axis (balancing on its edge). The ruler still weighs the same but the mass is further away from the centre. So by using a H section instead of a narrower solid square section, you move the mass away from the centre and make it stiffer.Quote:
Thats kinda how i took it, cheers for the info tho :)
No worries :)
All this sex talk is giving me the rod with a H section please carry on Oli and finish me off lolQuote:
