1.7 td engine next for better fuel economy
Trackday prep.
New pads all round, trying out the DS3000's again as they are £100 cheaper than the Carbon Lorraines. GM rears.
http://iainel.co.uk/images/forums/NovaWIP2b/399.JPG
I needed to fit my new front exhaust flexi, so thought I'd tackle the exhaust situation while it's off. Removed and backbox cut open to inspect:
http://iainel.co.uk/images/forums/NovaWIP2b/400.JPG
Not much deadening left in there:
http://iainel.co.uk/images/forums/NovaWIP2b/401.JPG
The small centre silencer has also somehow collapsed on the perforated tube. No idea how this happens but looks to be creating quite an obstruction.
http://iainel.co.uk/images/forums/NovaWIP2b/402.JPG
So decision was made to remove it and replace with some straight pipe:
http://iainel.co.uk/images/forums/NovaWIP2b/403.JPG
Tacked in place:
http://iainel.co.uk/images/forums/NovaWIP2b/404.JPG
Access for re-packing the rear box was tight so the rest of the box outer was removed:
http://iainel.co.uk/images/forums/NovaWIP2b/405.JPG
Acousta-Fil wadding, 400mm wide 2 metres ordered. This is supposed to expand with heat and deaden very well.
http://iainel.co.uk/images/forums/NovaWIP2b/406.JPG
Used about 1.8 metres re-packing it around the perforated tube and tucking it in the box.
http://iainel.co.uk/images/forums/NovaWIP2b/407.JPG
Welded everything up and gave it a waft of VHT paint:
http://iainel.co.uk/images/forums/NovaWIP2b/408.JPG
While the welder was out I gave the centre box a little more support too, just cos.
http://iainel.co.uk/images/forums/NovaWIP2b/409.JPG
Sound meter testing will be formally done on the next trackday (Rockingham 13th) but my unofficial testing looks promising. It's a 105dB day next so should give me a bit of wiggle room.
Are we at a trackday? Did I not get an invite?
I've booked you on so be there or be square lol
Result!!
Top Wafting
I like it.
Any pics of the cable change set up?
It doesn't have cable change. I had to change the box to a cable clutch. Change to cable. Cable change. Gerrit?
Oh sorry! Cable clutch, not gears.. ha sorry.
