Cracked on too day.
Well got these yesterday. Needed fittings for my oil cooler, so i popped to a local hydro place and got these..
http://i6.photobucket.com/albums/y23...nerefit413.jpg
Then took the std cooler lines apart..
http://i6.photobucket.com/albums/y23...nerefit417.jpg
Then found some strong pipe which i had in stock.. And made this up..
http://i6.photobucket.com/albums/y23...nerefit411.jpg
Polish jubilee clip of coarse..
http://i6.photobucket.com/albums/y23...nerefit415.jpg
That gave me this...
http://i6.photobucket.com/albums/y23...nerefit414.jpg
Fits hidden in the front, wing against the front panel. Which i might made a few air holes in, as it will get direct air there.
Now who remembers the water pipe i didn't like?
http://i6.photobucket.com/albums/y23...aterpipes1.jpg
Too many clips on it, just looked messy..
While i was getting the oil cooler fittings i asked about tubing.. So popped back and asked if they could bend me something like the pipes shape..
http://i6.photobucket.com/albums/y23...nerefit416.jpg
Needed a little cutting to shape. And a good polish..
(after a light buff)
http://i6.photobucket.com/albums/y23...nerefit418.jpg
Made up..
http://i6.photobucket.com/albums/y23...inerefit41.jpg
Fitted.
http://i6.photobucket.com/albums/y23...inerefit46.jpg
http://i6.photobucket.com/albums/y23...inerefit45.jpg
Also got a nice set of better fitting stainless P clips to hold the fuel lines up..
http://i6.photobucket.com/albums/y23...inerefit44.jpg
Filled the engine was oil, gear box oil, water and then fuel, fit new plugs. Battery on... Turn over to get the oil pressure up.. Then try and start....
And boom it started right almost right away. One slightly noisey tappet.. Then switch off as one water pipe was leaking.. Tighten up hose clip. Re start engine, good steady idle, no bad noises.
The fuel return to the tank is leaking a bit, so need to check that out. But she runs! :)
