what was her job??
Accuracy Check Technician (Dispenser in a pharmacy)
it doesn't sound that stressful, simply make sure the right amount of the right stuff is supplied.... is she a bit high strung??
is it a solid pipe then? cos you can get joiners for that.. i've fixed hiabs that way before..
if its a flexi, then someone somewhere will be able to fix it.
what about a breakers??
solid pipe yeah,about 10feets worth in total,then a couple of flexi's.
Solid had rotted away.
Breakers would be a false economy IF I found one as they will no doubt be the same,as its in front of the rad in an area ya cant get to,nobody will have rust proofed them.
I did as soon as they were fitted,ballache of a job!
look around for a hiab/taillift place. they'll be able to sort you.
all sorted now
To55ers that can't use motorways! Either sit in the middle lane. Or lanes 3 and 4 and not use them all correctly. And the daft tw@ts that don't use the slip roads ad join a motorway at 40mph! Fu£kTards!
I had a crap day at work and then come home to find out my cat has been ran over only 4 years old still had like 10 more years what is matter with people having to run things over I fill so mad
