ive got simmilar chassis plates but made from galvonised
wooo you still going ???? lol GIVE ME A B !!!!!! GIVE ME A E!!!!!! GIVE ME A N!!!!!!! GIVE ME A N!!!!!!!!! WHAT DO YOU GET ?????
A BLOKE ON A MISSION !!!!!!!!!!!!!! lol
i can see this whole car being chrome in a few yearlol thats your next mission, gotta say though you are dedicated,whenever i see a car with chrome all over it at the shows in its immaculate, first words are thats nice quickly followed by funk that thats to much work for melol
whats the point of the blanking plate on the sump?
good work as usual, keep it up.
Brucer it moves the oil level sensor fitted there as standard. Just a bit neater looking than cutting the wire off.
does the plug still need to be connected or will it not cause any fault stored in the ecu?Quote:
Originally Posted by Iain
Wire isn't for the ECU it's for the warning light on the original vehicle is it not?
You cant fill them, the oil will drain out of the hole in them, like it does when the engines off. If just put them together in the oil bath (red tub) so there is lube in them. The pump fits in the same way a xe/Clet one does..Quote:
That's good, but you'll need to grind that off to weld them on..Quote:
Originally Posted by paddy quinn
Just trying to get it right.Quote:
Originally Posted by GRUNT 16V
Shiney looks best, so i want it..lol Its worth putting them work in to get the finish(ish) itemQuote:
Originally Posted by mrT
Brucer, as Iain said the oil level sensor is only in Cav/Cally's and Astra's. So there's no real point having it in a Nova, unless you wiring it all up to put a light on when the oil is low.
Love this car! The work your doing to it looks awesome and look forward to seeing it a show at some point :thumb:
I know bud looks fab !!!!!!!!!!!! keep it going !!!! just dont forget that cups of tea help loads !!!1
