I found it was more my neck that hurt after working under the car, as i found i kept pulling my body up off the floor to put more effort behind the drill/grinder etc..
So 100% resect from me also on that one dude!
As said before R E S P E C T mate!
Have some rep
Think I'm glad I stuck to black Schtuz.
I can jack up my mk4 astra on the box section and it wouldn't even bend one little bit, just shows how weak Novas are to modern cars lol
Btw, can you not do what paul did and weld a box section on top?
Thank you very much :)Quote:
Originally Posted by saloonmad
Cause only men can put up with the sh*t? lolQuote:
Originally Posted by peester
Thank you very much, tbh it gets really funking annoying. Having no room to work and then where you do its still cramp as anything or you kicking something. But i'm hoping it worth doing. I got mine done just cracking on on the weekend, than a few hours each night.Quote:
Originally Posted by Jeff16v
A jig is the best way. I would love one! Just isn't the room in my garage.Quote:
Hoping it will be worth it.
hahaha easy way...lolQuote:
Originally Posted by bmw156
Cheers.
Originally Posted by kyl3_l
Thank you, i'm not filling it tho. As it will be being jacked up (in the right place) so don't want it damaging anything. Pins and a slide hammer and hammer and dolly will sort it enough.
Your a brave soldier,LMAO at getting stuck,i did that when i was in the "burning" phase of mine (used a hot air gun for some) feck me,it dripped down my sleeve tried shuffling away and cut my head on the beam mounting.Cue a garage full of swear words.
lol lol
Good lad, I cursed when simply undersealing mine, let alone doing that amount of work!
I had the car kinda set right so i could lay my head on my arm, but that ment my arm was held up at the elbow, my arms are killing today.. Perfect to carry exhausts around all day..Quote:
Thank you very much.
Thank you Sir, gonna do a lil metal fab tomoz, as i wanna cut the corner off the end of the chassis where the fuel line bit has rusted, just to check under it.Quote:
lol yeah deffo.Quote:
Originally Posted by Nova_Tek
The metal car makers used as got so much better, i bet a early (a or b reg) Nova would be alot stronger down there cause of the better steel.Quote:
Originally Posted by Mieran
I can box it in yes. If i have to i might well done that, just will be a bit of a delay but needs a must so you never know.
Nasty job but good work :)
Are you going to be able to spray the sealer on with it being on axle stands ?
Yeah i wriggled in there and then was stuck on the car and floor and between the axel stands..lolQuote:
Originally Posted by Andy
lol under seal is easier...Quote:
Originally Posted by SRimon
