The wet looks more fun :-)
Paul..
Paul..
Youre getting quite a bit of movement in your gear shifter when on/off throttle? What mounts are using?
Nice vids btw!
The wet was actually pretty fun Paul, just I prefer to lose control at high speed rather than low speed!
Will it's on solid TAS mounts, a few pages ago in my WIP I rebuilt the gearbox because a circlip wasn't seated properly causing movement in the gear shaft and therefore shifter movement, unfortunately it appears to still do it a little bit.... Might be a job for winter to try and rebuild it again.
I'm not a fan of the pins, but thy are a good job.
That wet lap looks like scarey fun. I was always told if you start to spin, use really light movement on the steering to correct, dont panic and over turn it... Just a random tip i was told.
That alternator looks the biz mate were can i get one
Im looking at changing mine after it turning the belt over twice at the weekend . Cheers dan
Mine used to invert the belt when it wasn't aligned properly. Slotting the bracket allowed me go line it up properly with the standard gear.
Alternator was from eBay and Vauxhall bracket was off genuine parts search on the net. Rosejoints and turn buckle were from McGill Motorsport.
;) cheers bud
Ready for next weekend?
My Ferrodo DS3000s are getting a bit low so will probably chuck on my Mintex M1144s for the day, but apart from that it's ready to roll.
No repairs, mods or improvements since the last trackday, it's a weird feeling.
You will notice a difference between those if its dry...
Paul..
