I too had a stat-less mocal jobbie, which obviously helps things keep cool at all times, as it means the oil is flowing through the cooler, without having to get up to temperature :)
Ok, but shouldnt you want the oil up to temp to work best tho?
They arent cheap tho are they...Quote:
Originally Posted by dan16v
They arnt to bad at all mate! not mega £££
Is that your cheap or mine?
update update lol
i thought you'd of got a brand new one and polished it up haha
Even with a mocal and oil flowing through it from cold its not going to take long for it to heat up. Think how small the cooler is, its only there to take the edge of temps. Plus if you drive steady for the first part of your jouney which everyone should i cant see any probs.
I think the sandwich plate was about £50 and the cooler about £70 mate:thumb:Quote:
A std cooler will do then really.Quote:
Originally Posted by garethcolley
Thats no tthat bad, thought it would be a long more.. Std stuff will do for the mo tho.Quote:
yea i bought the mocal stuff as the price was good and i didnt like the fitment of the std stuff (plus both coolers i had leaked from the unions)
Will get custom lines made up to run nicer and to where i want.
Thats a bad thing tho....Quote:
Thats what i said too, oil needs to be up to temp to perform best.
Mot list.
Trim metal boost/intake pipe. Done
Fit inlet pipe and afm. Done
Fit front bumper and grille. Done
Make and fit smooth grab handle. Done
Hoover and fit mats. Done
Fit sunroof motor surround restick ariel to screen and stick tax disc to window. Done
Clean windscreen. Done
Wash. Done
Check lights
Good luck.
i have always wondered about you.... :wtf:Quote:
Originally Posted by Adam
Its amazing people all ways feel the need to...
those wheels look well good what are thay
Cavalier Turbo's with chrome/polished finish i think?Quote:
Originally Posted by mattynova7
Come on benn, did it pass?
can buy mocal sandwich plates with or without stats, myne has a stat.Quote:
We left my house, with a light miss fire. Thinking even tho the plugs are new there not fully right, gonna pop to vx in the morning to get gen plug and some oil.
Cruzing on the motoway, water temp ok (fans works) oil pressure was ok.
Missed the road as the roads changed a bit since the google pic i used as a map was taken, which is when we started to smell antifreze and hot water, then the screen missed up and the pass mat for wet.
Pulled over to fine my header tank main hose had poped off and drain the tank. Bugger.
After pushing it back on and topping it up we followed Craig to his place, where it where it blew the pipe off again and dumped the water out again. Fit it again and it...
Passed!
Then blew it again. So this time i removed the wiper motor as the peiece of sh*t was right in the way and i thought might be pushing the tank out of place, looked ok.
Start on the drive home, (for peeps that know) got to tesco burseldon and it poped again. So when it to get some water and to see if they had a screw driver.
Not only did they have a screw driver.. The have a ratch driver set with 10 sockets and screw driver bits for £3.97... I mean really it was so cheap it was unreal!
Pick up some rain-x as well for £2 then 4lts of water and it was a total of £7 it was so cheap it was stupid. Fixed the car in the car park.
Justed on a sadly buzy motorway but found when booting it to get the boost up it would cut the boost off... Gay!
Dans thinks cause the engine was on evo5 chips the actuator has been wound right out, so the boost is getting cut cause i'm running the std ecu and chips.
So need to wind that in, and sort out the water pipe that keeps poping off.
Buts its motoed and drives ok.
Big big thanks to Craig (saloony)
:cool:
Nice one mate! better to have the teething probs at this stage!
Nice one Ben, and Dans right, you should be worried if you dont have nay teething problems! lolQuote:
Paul
Having a boosting prob at the mo,
Its dumping (i think) boost at about 4k. We think the acturtor has been wound out tofar.
Yeah 4k-4.5k it was just cutting dead... shame, i wanted to give it some large lolQuote:
Looks like its been wound in to give more boost, gonna wind it out in the morning.
Benn you got a boost gauge fitted?
Yes thats how i know there its dumping boost.
Fitted my track/pov bumper for the mot as i knew the gsi would need a lil trimming.
Mouth is right over the ic which is perfect.
http://img.photobucket.com/albums/v3...imfitting6.jpg
http://img.photobucket.com/albums/v3...imfitting7.jpg
Wanted to get the gsi bumper on tho, so while letting it cool down to day between test drives i fitted it, then removed it for a lil trimming...
http://img.photobucket.com/albums/v3...imfitting9.jpg
What i like is that you can only really see it when down low..
http://img.photobucket.com/albums/v3...rimfitting.jpg
On the mouth onthe gsi theres a lip, i had to trim this back as it was touching.
http://img.photobucket.com/albums/v3...imfitting2.jpg
All fitted.
http://img.photobucket.com/albums/v3...imfitting5.jpg
http://img.photobucket.com/albums/v3...imfitting4.jpg
Got my pillar trims fitted too.
http://img.photobucket.com/albums/v3...imfitting8.jpg
http://img.photobucket.com/albums/v3...imfitting3.jpg
Fooking stunning mate, Are the polished rims going back on for Billing?
Yep yep.
Looking good benn, welcome to the world of boost cutting!
lol corse yeah you have it too...
Woohoo looks like a car again :) Well done mate.
Does look excellent mate, you've done a really good job of it!!
Just need to get it driving nice...
Front ends all stripped off again...
uh oh why now ?
your car does nova's a world of good, looks smooth but has a nasty bite to go with it, very jealous :(
