Martin those pics are of freshly bored/honed engines, Your never see a used engine in that condition.
I dont know a lot about these things but can you not get it slighly bored and honed again with new rings to match? While its apart I'd deck/skim the block too to make sure its straight.
No that's is my point, cant feel anything with my finger. Had no probs with compression either..Quote:
Originally Posted by bmw156
I know how a bore will look when just honed or bored.
Si,
Yeah i can get a honing done then re ring it. I cant see why i'd need to skim it when there was no probs with the hg or anything..
Like he says, to make sure it's straight, however a steel rule and daylight also works for this :)
I know that, but what i mean is... Is it wasn't then the hg wouldn't seal...
I am gonna check it's flatness tho.
to be fair benn i got a head from a friend he said it was a good non porous head and came from a running car,i had it pressure tested and the skim they did was very very light and to be fair after seeing how much had been skimmed i wouldnt bother,cost me £75 for pressure test and skim,if id already knew the head like you know yours i wouldnt bother skimming it its £75 better spent elsewhere in my opinion,ps keep up the good work
i also enquired about the block and was advised by the engine builder that he has only known of a warped block twice in 30 years of engine work
What?Quote:
Originally Posted by davidfox280585
Mk, ah ok, yeah i'm gonna check it.
Yeah just backing up Simps on the fact his thinking is straight, just you don't need to go to those lengths to make absolutely sure its flat and level :pQuote:
Are you fitting a metal headgasket this time? If so they are not as forgiving as the standard headgaskets if the surfaces aren't perfectly flat.Quote:
i assume you are doing the valve guide seals whilst its apart?? as thats where the oil in number 4 will have come from i suspect, unless your turbo seals are dodgy? as for the pitting, its not ideal but not that bad at all. i would leave it but thats me, depends how anal you are lol
