Sounds like an expensive winter for you as well then with all the stuff you are fitting this time.
Yeah, flywheel, clutch and F28 and Quafe + more... Eek.
But i wanna do it and be able to not go in there again...
Make sure you get the correct oil pump seal for the Z20LET pump
What as in the gasket? So the brand new one for Vauxhall i have i wrong.. :(
Need the C20LET crank seal for the middle of the pump, the C20LET oil pump to block gasket and the Z20LET pickup pipe gasket/O ring.
Well done Lee - You've done your research
I thought I was going to see it ripping up the road:(
However, glad to hear that you plan to use it.
Just get it done, lovelly summers day, and hit the north wales B roads:)
Legend, any chance you know the pick up pipe gasket number?Quote:
Originally Posted by Lee H
I don't unfortunately, mine is coming from Steveboyslim with the modified pickup pipe.Quote:
Ah i'm fire up him a email. Cheers dude.
