POST 3 OF 6
Scary moment, trying the suspension on to check I've not messed up too badly:
http://iainel.co.uk/images/forums/NovaWIP2b/004.JPG
I did plan to use the OE tiebar brackets but I didn't like the angle the bush sat on the front, so I have decided to use the spherical bearing ones. Unfortunately due to this line of weld, I can't fit them on my new crossmember:
http://iainel.co.uk/images/forums/NovaWIP2b/005.JPG
So I'll have to use one of the ally spacers, bringing my tiebar down another 6mm or so:
http://iainel.co.uk/images/forums/NovaWIP2b/006.JPG
While prepping for the bracing I found some rot, eek:
http://iainel.co.uk/images/forums/NovaWIP2b/007.JPG
Chopped out:
http://iainel.co.uk/images/forums/NovaWIP2b/008.JPG
Making up some repair bits:
http://iainel.co.uk/images/forums/NovaWIP2b/009.JPG
All strong again:
http://iainel.co.uk/images/forums/NovaWIP2b/010.JPG
POST 5 OF 6
Legs for the radiator to sit on, moved it towards the middle of the car a bit and slightly forward for more exhaust clearance:
http://iainel.co.uk/images/forums/NovaWIP2b/021.JPG
Plenty of bumper clearance:
http://iainel.co.uk/images/forums/NovaWIP2b/022.JPG
I plan to use the new crossmember for jacking up the front, so I've made the front bumper easier to remove by bolting on some threaded sections to the original bumper brackets (just a mock up at the mo):
http://iainel.co.uk/images/forums/NovaWIP2b/023.JPG
Now it can bolt on through the front with 2 M12 bolts, all lined up properly:
http://iainel.co.uk/images/forums/NovaWIP2b/024.JPG
Nice fabrication there :)
epic. if this cracks its time to move on lol
Top work, can see your efforts and detailed pics innovating a few novas on here.
It's harder to weld against gravity huh? ;0 Should be plently strong-a-pull.
Simply amazing Iain, good work:thumb:
