Nice work on the car Iain, do you like the car handle with this mod?? with the circuit slicks its a big upgrade. I use Yokohama circuit slicks without LSD and the car sense more diferent.
With the EPAS Zeifer? TBH it went from a mostly standard 1.6 to a fully rebuilt/track prepped 2.0 with EPAS in one swoop so its hard to say exactly what benefits, but the steering is lovely and precise consisting of Corsa B EPAS, manual sensitivity controller, Quaife quick rack together with the Michelin slicks and Quaife ATB.
yes, that is i mean. fantastic car Iain, good work.
I have various upgrades to do to the poor beasty this winter, namely:
Replace the crossmember due to cracking
Fit a ZLET oil pump & pickup
New timing belt, pulleys
New shafts & CVs
Replace clutch due to damage
Check crank bearings as I've noticed some side movement in the crank, looks a little too much
Figured with all this to do it'd be easier doing it on a stand so tonight at 5:30 I started with a complete car, and a few hours later I had this:
http://iainel.co.uk/images/forums/NovaWIP2a/953.JPG
Cosmetic bellhousing damage from clutch letting go:
http://iainel.co.uk/images/forums/NovaWIP2a/954.JPG
http://iainel.co.uk/images/forums/NovaWIP2a/955.JPG
Supposed to be two springs on the cover plate here:
http://iainel.co.uk/images/forums/NovaWIP2a/956.JPG
Engine on stand:
http://iainel.co.uk/images/forums/NovaWIP2a/957.JPG
Engine bay doesn't look bad after all the abuse:
http://iainel.co.uk/images/forums/NovaWIP2a/958.JPG
Or does it, more signs of cracks when you poke a bit closer.... Uh oh. This is by the alternator cut out.
http://iainel.co.uk/images/forums/NovaWIP2a/959.JPG
Additional plan may be strengthening kit, extra welding and an engine bay respray too then...
Good work, now its time to refresh the little nova:thumb:
It seems everywhere I've added metal/weld/strength it's cracked around it. For example the crossmember. I do worry just adding more will move the problem elsewhere.
In two minds whether I want to put in a beefy crossmember or just a standard replacement with this in mind. Although if custom I can make it lower down and move back to poly bushed tiebar brackets which should batter the crossmember less than the lowered rosejointed items I have.
Bell housing is just surface and will be fine. What's the clutch friction plate like, any damage as seems to have loads of meat left which is a shame?
That stand and crane look spot on and the loan price was only a lifetime supply of jelly sweets for me :)
why didn't he use his winch lol
